Old 2nd May 2012, 02:14 AM   #11
mjurban is offline mjurban  United States
This topology has been made to work, but it usually involves providing some sort of reference voltage to help define the operating conditions of the VAS. I'm sorry that I can't say much more than that, because I only glanced at the various discussions of the subject on this forum. I will say that those who have been able to make it work have been very pleased with the performance, so it might be worth while searching in the forum archives to find some of the solutions.
Old 2nd May 2012, 02:36 AM   #12
I did a quick search, here are a few threads on the subject:
Complementary input stages with current mirrors
HEEEELLLPPP : M. Randy Slone Mirror Image Topology Construction - Troubles
Fresh fix for *that* Slone amp (ie yet another symetric topology)
Unstable VAS current in amp from Slone book
As you can see, it's a problem that's been extensively discussed. I still think Bob Cordell had the best solution, but I couldn't turn it up with the simple search I did. His comments are worth searching for.
Mike
Old 2nd May 2012, 08:57 AM   #13
Well the lower LTP putting out -40V on the bases seem more like a issue with the 2N5401's rather than the usual issues discussed about this topology.
The point of life is to build atleast one audio amplifier before you die.
Old 2nd May 2012, 09:47 AM   #14
This amp will never work properly, like mjurban already mentioned the bias currents for the vas are not defined, rather ask Bob Cordell for his solution as published in his book. I dont think he has shown it here yet.
Old 2nd May 2012, 10:06 AM   #15
Your talking about the first circuit i posted that just have the 18k resistors in place of current sources, right ?
Old 2nd May 2012, 10:33 AM   #16
Tekko Im afraid the second suffers the same fate. Mjurban has shown the threads where the problem is discussed, Cordell has the simplest solution.
Old 2nd May 2012, 10:37 AM   #17
I've replaced all the input stage transistors and now it no longer does what it did before, now its showing signs of life as in a almost square wave oscillation which for me is a victory as yesterday was pretty much a day of fail.
Now to replace the 1.8 ohm resistors i accedently used with something bigger and see about adding some caps to the VAS's and the drivers.
Old 2nd May 2012, 10:58 AM   #18
Take a look at what happens with the output transistor biasing, first signs of problems.
Old 2nd May 2012, 12:01 PM   #19
So i assume the issue everyones talking about is that i cant be biased, its either zero bias or near dead short bias.
Thats where im at right now, the amp works and play music but i cant bias it.
Old 2nd May 2012, 12:29 PM   #20
So this is the actual circuit as it stands right now: http://i.imgur.com/96bKv.png
I ran out of 2N5551's so i dident build the current sources. The dc offset on the output is roughly 10mV accoding to the scope.
I have not yet decided if im gonna keep working on this or just scrap this circuit alltogether and stick to the blameless topology i've been using up to this point.
The Most Symmetrical CLASS A Amp I've ever made lineup Solid State 2 15th September 2010 10:23 AM
100Watt MOSFET Amplifier (Amos 100) suds Group Buys 0 9th January 2009 07:12 AM
HELP NEEDED: 400W symmetrical amp Mazeus Solid State 6 15th February 2006 09:41 PM
Copyright ©1999-2013 diyAudio
