Please suggest a high rail voltage (160V) amplifier - Page 2 - diyAudio
Old 29th April 2012, 02:48 PM   #11
Jay is offline Jay  Indonesia
Originally Posted by KatieandDad View Post
Here's one.
It does use split rails again though.
http://www.elektropage.com/images/ci...r_Shematic.jpg
Thanks for the link. I like the circuit but I forget to mention that I will use N-channel device only, preferably mosfet in ISOTOP case (their relatively high Ciss makes it even more difficult to work with most circuits).
Old 29th April 2012, 03:03 PM   #12
Banned
Are those isotops STE47N50's ? I have twelve of those that i was planning to build a stereo amp with, i built a ugly prototype which can be seen here: NMOS amp in stereo - YouTube
The plan is to use six fets per channel, it'll need some hefty drive though, bit since this amp is not intended for hifi, i am not really worried about frequency response.
Schematic of the test amp in the video: http://i.imgur.com/z7i8h.png
Old 29th April 2012, 04:05 PM   #13
Use a second transformer of the same to cut the voltage in half again...
Either for the supply, or as an output transformer. Latter choice could
make an all N-CH solution easier... You are at a voltage where triodes
in the front end could also make sense.
Old 29th April 2012, 11:40 PM   #14
I have at least six models. In front of me I have E110NA20. But I think I have also STE47N50.
Hi, I have downloaded the schematic the day you posted it, even if imho such topology will not give good sound. Even if these isotops have high Ciss, they can still sound good. Of course it needs relatively high current.
With around 6000pF of Ciss, I think the ISOTOP is comparable to 3 to 6 "ordinary" mosfets. So 3 pairs is a lot. One isotop is capable of very high current, so 3 pairs is feasible only if very big power is expected.
Old 30th April 2012, 02:15 AM   #15
Good idea. Not perfect (efficient) but if nothing else it is a solution I can use, especially when the VA rating is too low for a working amplifier circuit.
Either for the supply, or as an output transformer. Latter choice could make an all N-CH solution easier...
This output transformer thing is new to me
Yes, TubeCad DotCom has such thing but with no gain. Actually I already have a solution but I think people might have better idea because imo this is a frequent common situation where people get in touch with step-down transformers. Well, of course not in US or Japan.
Old 30th April 2012, 08:05 AM   #16
Banned
The alternative is separate drivers for each output pair.
What kinda topology do you have in mind ?
Old 30th April 2012, 10:12 AM   #17
Use 160Vdc single ended PSU. This could potentially give ~300W into 8ohms.
Build the amplifier with AC coupled input and AC coupled output.
This alone will save a lot of cost in capacitors. 200Vdc capacitors are not cheap.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 30th April 2012, 10:45 AM   #18
Banned
Something like the QSC or whoever it was topology might be worth a try, wheres the amp output is grounded and the speaker output is the center point between the two rail capacitors.
The all NMOS output as you say is not a very good topology, in fact it simulates really poorly no matter what, but some of the ppl doing mosfet amps seem to prefer NMOS output over complementary output as there is no good match between the N channel and P channel vertical mosfets.
Old 3rd May 2012, 06:26 PM   #19
Thanks I will check the QSC. I forget the schematics but as far as I can remember it is not applicable. I think it was the complementary type.
Yes, I know. Quasi is chosen for economical reason only, not P-N matching reason. But for PA usage, the simulation performance is more than acceptable imo. Don't know with reliability as there is that trade-off.
Old 3rd May 2012, 06:32 PM   #20
Yes I used AC coupling (Cap at output) as there is no other (better) options, right? I don't have issues with caps availability tho.
High Voltage BjT's for Pre-driver stages of High Power Amplifier - Overview tiefbassuebertr Solid State 54 12th March 2017 01:01 AM
F5 loaded rail-to-rail voltage? CanAm Man Pass Labs 40 20th March 2011 07:43 PM
High uF value 160v cap source tjencks Parts 15 28th July 2010 05:33 PM
need a high voltage operational amplifier! xiaonan Chip Amps 6 7th September 2006 04:37 PM
Solid-State High Voltage Amplifier G-Daddy Solid State 6 18th December 2001 05:10 PM
Copyright 1999-2017 diyAudio
