Stability of a JFET cascoded by another JFET
Old 29th April 2012, 10:32 AM   #1
steveh49 is offline steveh49  Australia
Default Stability of a JFET cascoded by another JFET
In the attached simplified schematic, C2 stabilises the global feedback loop (closed by R3), but how does one predict whether the feedback loop formed by C2 around the two JFETs will be stable? I would use the same type of JFET in both positions, or the same family sorted for different Idss.
Old 29th April 2012, 12:15 PM   #2
Normally we use a high gm/low Vp device for the amp and a low gm/high Vp device for the cascode.
I don't know what effect that has on performance, nor sound.
I think you need AC coupling at the input.
regards Andrew T.
Stability of a JFET cascoded by another JFETHide this!Advertise here!
JFET cascoded with tube gain calculation Joshua_G Tubes / Valves 20 4th June 2012 01:45 PM
Cascoded jfet buffer rbroer Solid State 22 1st July 2008 02:43 PM
Jfet Cascoded BOZ bobsinclar Pass Labs 26 21st September 2007 08:23 PM
Krazy JFET-cascoded Pass BOSOZ jh6you Pass Labs 60 17th March 2006 01:19 AM
Cascoded jfet in X-BOSOZ?? Magura Pass Labs 44 31st January 2006 09:00 PM
Copyright ©1999-2017 diyAudio
