jfet preamp - does a jfet exist that'll work at just 5V supply?
Old 27th April 2012, 03:32 PM   #11
scott wurcer is online now scott wurcer  United States
scott wurcer's Avatar
Originally Posted by peskywinnets View Post
I did, but equally, you clearly haven't locaked in to my comment about NOT using opamps!
BF862 costs almost nothing and is widely stocked, and rarely has Vp over .5V or so.
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 27th April 2012, 03:32 PM   #12
peskywinnets is offline peskywinnets  United Kingdom
Originally Posted by Tekko View Post
What is the application ? Is it an amplifier or just a inverter ? Even the single jfet amplifier needs its gate biased somewhere between GND and Vcc = coupling cap needed.
If its just a inverter, theres ttl and cmos logic which is designed for 3.3 and 5 volts.
It's an audio preamplifier.
If I use a self biased jfet, then the gate biased to ground through a high value resistor, but will actually be negative wrt to the source, therefore no input DC blocking cap needed.
Thanks...how can I work out what gain can be coaxed out of a jfet...I realise it's related to transconductance, but I'm having diffs gleaning which part of the datasheet that's etracted & what formula to use? I'm looking for a voltage gain of about 3x ...doable?
Old 27th April 2012, 03:34 PM   #13
zinsula is offline zinsula  Switzerland
zinsula's Avatar
What is the voltage swing at the input?
How would you use it? as a buffer, i.e. common drain, or should it amplify, i.e. common source?
If you can't trust your ears, then CLICK HERE
Old 27th April 2012, 03:37 PM   #14
voltage swing is about 1V max peak to peak (but averaging about 300mv)....I seek a voltage gain of about 3x out of this circuit.
Just experimenting right now to establish the pinch off & the IDS of the J110 I have here....then I can work out the biasing!
let's see if I have this right....
gate grounded
source grounded
drain 100R
VCC= 5V
voltage drop across the 100R resistor is 0.489V ...therefore an IDS of 4.89mA?
Old 27th April 2012, 03:52 PM   #15
zinsula's Avatar
2N3819 from Vishay is easily available. Check the Datasheet, if you set ID with appropriate source resistor at about 5mA, you should have enough headroom at the input.
But...if you have 1Vpp and you want 3Vpp, this will be difficult. There isn't just enough headroom.
And how do you handle the output? Midpoint will be above ground....
Old 27th April 2012, 03:55 PM   #16
zinsula's Avatar
[...]100R resistor is 0.489V ...therefore an IDS of 4.89mA?
Yes.
But if you are going to ground the source, you might be able to swing the negative input half wave, but not the positive....more than 0V G-S will only forward bias the G-S...no good.
Old 27th April 2012, 03:55 PM   #17
You make a good point...I'll have to reign the gain expectations back a bit.
Old 27th April 2012, 03:57 PM   #18
Yes.
But the source will be sitting at a DC level higher than 0V ...so it won't be forward biased on the positive signal swings. So long as the source is biased higher than the largest voltage input swing, then I should be ok?
Old 27th April 2012, 03:58 PM   #19
Tekko is offline Tekko
Banned
Why is DC coupling a requirement ?
Its a common misconception that dc coupling improves bass response.
Also in most audio applications you dont even want frequency response down to DC.
Besides any imaginable audio source will have a dc blocking cap on the outputs anyways.
Old 27th April 2012, 03:59 PM   #20
jcx is offline jcx  United States
"not using op amps" is not an engineering design criteria - maybe for a homework assignment
the better way to use engineering design skills is to specify the problem in performance terms, define input, output signals, levels, available supplies, area, cost , power requirements that the application demands
specifying device tech from the start is not a proper performance related constraint - you rule out too many options you may not be aware of
jfet preamp - does a jfet exist that'll work at just 5V supply?Hide this!Advertise here!
Complementary JFET-JFET cascode input, BJT VAS-Drivers, Lateral Output Neutrality Solid State 61 2nd October 2015 06:35 AM
JFET preamp? asc Chip Amps 6 10th May 2013 08:21 AM
FS: PreAmp with Complimentary JFET Diff input & JFET ouput USAcircuits Vendor's Bazaar 12 21st June 2011 11:02 AM
Can I replace BF245C JFET with J201 JFET? bigmike216 Parts 2 7th December 2005 06:50 AM
BJT cascoded with a Jfet: how can I make it work? Bricolo Parts 16 7th November 2004 06:29 PM
Copyright ©1999-2017 diyAudio
