Old 6th February 2013, 06:59 AM   #81
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
Not exactly
Most had 60V/uSec Slew Rate at full power (a more meaningful rating than simple "Frequency Response" which is usually measured ar 1W); the biggest ones (such as the one shown) "only" 45V/uSec.
The choice of the best Recording Studios in the World, including the BBC.
http://www.hhamplification.co.uk/dbf...s/mosfetvx.pdf
Old 6th February 2013, 08:47 AM   #82
djk is offline djk
djk's Avatar
Barely meets the Jung criteria of 0.5V/µS per peak volt of output.
I would prefer to see a little more current available to push all that gate capacitance.
"The choice of the best Recording Studios in the World, including the BBC."
Hyperbole, no comment.
(my standards are a bit higher than theirs)
Candidates for the Darwin Award should not read this author.
Old 6th February 2013, 10:13 AM   #83
MOS FET's ( Exicon ) only need about 1 mA to work acceptably . Sure the gate capacitance at up to 1nF is a problem . My experiments say 5.6 mA is about optimum . 600 Watts at 20 kHz for music ? More like 10 W and hope the tweeters can cope , ears of the punters won't . 8mA is not my cup of tea ( too good ) . This seems to be a default value in many amps . Distortion caused by not bandwidth limiting such an amp is folly . There is no value in entertaining mice . Myself I would have the amp as hi fi with one set of outputs . Then bandwidth limited with other FET's switched in . I would have a heat-sink for normal use backed up with fans for fairground use . The punch offered by many FET's is a positive , plenty of HF maybe not ?
I was in Cuba recently . I am sure their amplifier was fine . I just wish I had brought some Motorola horns with me . It would have been nice to hear 3 kHz and above . A few other bits and I might have integrated them nicely ( stop them quacking also ) .
Now to the crunch . I bet that an over engineered power supply and what I have just described will sound better to the punters more than most of the sterile hi fi amps . The bonuses are . Robust ,simple , no emitter resistors . Can be driven by a ridiculously small VAS and can sound silky smooth . What must be remembered is many who bought these amps were changing over from valve equipment . They wouldn't tolerate the unpleasant squeaks of typical hi fi . Most people who enjoy this forum would last 5 minutes in that world . And now the crunch . At the drop of a switch this amp with no complexity becomes a nice domestic amp . The usual criticism of the Hitachi design was it is too simple to deal with HF distortion . The Hitachi graphs say totally different to that . An op amp with serious current . To me this is as serious a defect in understanding . Like saying a diesel car could never win a race , or if it did only something minor like Le Mans !
https://www.google.co.uk/search?q=go...%3B1400%3B1050
Old 6th February 2013, 12:44 PM   #84
JMFahey's Avatar
Hyperbole is something pulled out of thin air .... this is *fact* ... and I see it hurts.
Just google "HH " and "BBC" and you'll get a million hits.
All mentioning something like "commonly used by many broadcasting studios, including the BBC. " , "many of which are still in use in studios all over the world" and so on.
Well, *this* is hyperbole.
Well, that's a quite precise evaluation of the situation.
Just adding that not only they were changing from "valve equipment" but from "the best valve equipment"
Oh well.
Old 6th February 2013, 07:13 PM   #85
100 % right . I will have a drink on Thursday with John . I think Carlsbor was his favourite fairground amp . He has repaired everything I have ever named , uses Turbo Sound himself . As you say about makes and quality .
HH proves that something that others would dismiss have successful commersial lives . When I see amps that are 70% protection systems I despair . It is possible to build things that are simple and work .
Old 29th March 2013, 06:33 PM   #86
Aniket is offline Aniket  India
Aniket's Avatar
Default 980W@2R 0.169%THD@20kHz
Originally Posted by vedmitraa View Post
Here is a circuit of 2n3773 8 pairs,70-0-70 volt d.c. 42 volt output at 0.497% distortion power output 887 watts into 2 ohm
With just 24mA bias per device, and 9.3nV DC offset. 980W@2R ultra low THD of 0.169% @ 20kHz, with 5 pairs MJL21193/4. THD could be further reduced using more output pairs.
Just simulated my design, wonder it would perform like this in real.
Aniket
Old 29th March 2013, 07:09 PM   #87
I think you could build it with a pair of devices and try 8R . How is it at 100 W 8 R ?
24 ma should be excellent as bias .
I often still use TO3 devices . I have no problem using flying wires to the PCB . That way adding a few is not difficult .
I have even run transistors in buckets of water . It sometimes works well enough until the water contaminates . 1 bucket per device . I think I have gone to 70V before now ?
My dream is to put some TO3's with their heads in a water pipe . It should work reasonably well . Not perfect as the die is on the connection side . A pump will be needed . Isolated TO3P even better . 90% could be in the water .
Old 29th March 2013, 08:10 PM   #88
JMFahey's Avatar
Why, of course not.
There's a ton of important parameters that simulation is not considering which will affect end results big way.
Old 29th March 2013, 08:14 PM   #89
AndrewT is online now AndrewT  Scotland
Aniket,
ask the simulator what current is passing R3 and R4?
Old 30th March 2013, 03:03 AM   #90
Aniket's Avatar
1.079 and 1.08 mA through R3 and R4 respectively. Images attached.
Aniket
Which class D amp for a 100W +/-28VDC power supply ? 00940 Class D 3 29th August 2009 05:17 PM
Aem 6005 100w Power Amp Modules GeeVee Swap Meet 1 7th January 2007 08:36 AM
looking for simple discrete 100W DIY amp halusha Solid State 27 8th December 2006 10:30 PM
100W Amp from car battery as power source subashcobi Solid State 2 18th October 2006 02:13 AM
simple designs for 50-100W amplifer TomJ Solid State 2 7th February 2003 05:17 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
