Simple 100W power amp
Old 18th September 2013, 01:36 AM   #321
Aniket is offline Aniket  India
Aniket's Avatar
Hello dvv,
my boards are already manufactured 3 months ago, i sent only the pdf files to the manufacturer.
In fact, I need the PCB layout files.
Aniket
Old 18th September 2013, 12:10 PM   #322
alex mm is offline alex mm  Romania
alex mm's Avatar
........ but you have gerbers files
Alex
Old 18th September 2013, 12:27 PM   #323
Aniket's Avatar
Hello Alex,
I have the gerber files, but these files have some problem importing them in Sprint Layout 6.
that's why I am asking for layout files.
Aniket
Old 18th September 2013, 12:29 PM   #324
nigel pearson is online now nigel pearson  United Kingdom
Hi Alex , Hi Aniket . Another member has asked me about a phono stage . We can do a lot on a ready made PCB for less than $1 from RS ( 4 to do the job ) . Problem is he wants it small ( SMD perhaps , perhaps not because good capacitors are large ) . If we get that far any advice ? Even with Gerber files it needs someone to do it . I have seen PCB's for $10 . That seems too good to be true .
Old 18th September 2013, 12:56 PM   #325
Aniket's Avatar
Hi Nigel,
I got my PCB's manufactured locally. I sent only the pdf files to manufacturer(he created the gerbers himself). Minimum quantity to order is 15, so i ordered him 16. He charged me 500 Indian rupees (~10$) per PCB, which itself is a good deal, considering the size of the PCB, and they were very good quality.
Hi Alex,
m waiting for the layout file.
Thanks in advance.
Aniket
Old 22nd October 2013, 07:53 AM   #326
arun9998 is offline arun9998
Originally Posted by Aniket View Post
With just 24mA bias per device, and 9.3nV DC offset. 980W@2R ultra low THD of 0.169% @ 20kHz, with 5 pairs MJL21193/4. THD could be further reduced using more output pairs.
Just simulated my design, wonder it would perform like this in real.
Aniket
whitch simulation software is using
Old 22nd October 2013, 11:34 AM   #327
Aniket's Avatar
Multisim 13
Old 23rd October 2013, 04:32 AM   #328
Gost22 is offline Gost22  Bolivia
Banned
Hi guys!
Guys I am on the simple schematic developed this audio amplifier.
Somewhat satisfied with its sound!?
So if you have some ideas about some changes go ahead with the comments.
Regards!
Old 23rd October 2013, 04:46 AM   #329
Banned
Originally Posted by Gost22 View Post
Hi guys!
Regards!
Old 23rd October 2013, 07:23 AM   #330
dvv is offline dvv  Serbia
I'd just like to say that its voltage slew rate is rather low, at around 5 V/uS. I'm no slew rate freak, but ideally it should be at least 14 V/us to satisfy the criterion of 0.5V/uS per 1 V of peak output. Preferaby 28 V/uS, to satisfy the criterion of 1 V/uS per peak volt output.
In other words, you may experience some slew rate induced distortion (SID) with fast music material. This is distorion caused by an amp's inability to properly track the signal because the input signal is faster than the amp.
Also, I don't see much point in using electronic protection as there is an output fuse.
Per Aspera Ad Astra.
Simple 100W power ampHide this!Advertise here!
Which class D amp for a 100W +/-28VDC power supply ? 00940 Class D 3 29th August 2009 05:17 PM
Aem 6005 100w Power Amp Modules GeeVee Swap Meet 1 7th January 2007 08:36 AM
looking for simple discrete 100W DIY amp halusha Solid State 27 8th December 2006 10:30 PM
100W Amp from car battery as power source subashcobi Solid State 2 18th October 2006 02:13 AM
simple designs for 50-100W amplifer TomJ Solid State 2 7th February 2003 05:17 PM
