Old 28th April 2012, 03:28 PM   #11
What is that board from ? Kinda looks like a board to some old kit.
The point of life is to build atleast one audio amplifier before you die.
Old 28th April 2012, 06:13 PM   #12
sakis is offline sakis  Greece
sakis's Avatar
very very important : the cable you use from pcb to transistors you need to split it having a flat cable including B C E connections is a very bad thing to do...twisting is even worst .
You need to at least remove the base cable from the pack
SERVICE ΕΝΙΣΧΥΤΩΝ ΚΑΙ ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Old 10th May 2012, 08:02 AM   #13
Aniket is offline Aniket  India
Aniket's Avatar
Thanks friends.
I did some changes. Increased the +ve FB resistor to 3.3K from 2.2K.
Increased 3.3K resistor to 5.6K keeping the zener in place. The amp stays cool at idle, but the output trans. get a bit hot while playing music. Sound is really good with crisp treble and clear vocals. Bass is good too.
@Stormrider- KSA3503 are really hard to find, i looked out for MJ15003/4 but they turned out to be fake ON semi's.
@AndrewT- Input trans. are BC556B, please advice if BD139/40 are not good Vas devices. Mention any substitutes.
Aniket
Old 10th May 2012, 10:50 AM   #14
AndrewT is online now AndrewT  Scotland
Look up Greg's data for devices. He has a table of suggested VAS devices with a few oddballs thrown in for comparison.
Old 10th May 2012, 11:02 AM   #15
djk is online now djk
djk's Avatar
Add a second pair of output transistors before attemting >50 watts output into 4 ohms. "
A Crown D150 only uses one pair and can drive 140W/4Ω, the D150AII was rated at 155W/4Ω.
http://www.crownaudio.com/pdf/legacy...spec-sheet.pdf
The original DC300 would do 340W/4Ω at clip with two pair of 2N3773.
Candidates for the Darwin Award should not read this author.
Old 10th May 2012, 02:51 PM   #16
Aniket's Avatar
Please send me Greg's link
Old 10th May 2012, 03:10 PM   #17
What is the rail voltages of that crown amp ? Looking at the 2N3773 datasheet, at 50V Vce, you can pull about 3A through a single 2N3773, so up to 50V rails seem to be safe with a 4 ohm load.
Old 15th May 2012, 05:07 AM   #18
Aniket's Avatar
Should i add more output trans. ??
will this increase performance/ power?? by how much?
Old 15th May 2012, 07:25 AM   #19
djk's Avatar
"What is the rail voltages of that crown amp ?"
If I remember correctly, about ±50V.
"Should i add more output trans. ??
will this increase performance/ power?? by how much? "
If you like.
If you have a good heatsink and adequate thermal grease and good insulators it is probably OK with one pair.
A second pair would just allow it to handle low impedance loads better, it would probably not put out any more power.
Old 15th May 2012, 08:10 AM   #20
Moar OP devices does lower THD alittle though, atleast in ltspice it does.
Which class D amp for a 100W +/-28VDC power supply ? 00940 Class D 3 29th August 2009 05:17 PM
Aem 6005 100w Power Amp Modules GeeVee Swap Meet 1 7th January 2007 08:36 AM
looking for simple discrete 100W DIY amp halusha Solid State 27 8th December 2006 10:30 PM
100W Amp from car battery as power source subashcobi Solid State 2 18th October 2006 02:13 AM
simple designs for 50-100W amplifer TomJ Solid State 2 7th February 2003 05:17 PM
Copyright ©1999-2013 diyAudio
