#41 |
#42 | ||||
Mooly thanks SOOO much for working with me. You've taught me a lot! |
#43 | ||||
Those figures mean it can supply that voltage across that load impedance. Make the impedance lower and the output voltage will fall away and possible distort too. So the input impedance has to be at least equal to and preferably higher than the minimum value the component can drive. Another way of thinking of it... a large 12 volt battery can supply plenty of current into a load such as a bulb or motor. If you add a 10K resistor in series with the positive battery terminal there is still 12 volts on the end of that resistor but it won't now light a bulb or run a motor. The "output" impedance of the battery is now 10K and limits the current. Output impedance of a component is similar. So a 10K load will cut the 12 volts down to half and so on. So we make the input impedance of most amplifiers high relative to the source. In practice that means 10K and above. Quote:
When a transistor is used as an emitter follower the emitter voltage follows the base voltage less around 0.7 volts. The transistor has a "high" input impedance on it's base and low output impedance on its emitter. The current gain is determined by the property called "hfe" and for a small transistor is around 100 or more. That means with 1 milliamp flowing into the base and emitter junction, a curent of 100 milliamps will flow from collector to emitter. The emitter current would actually be 101 milliamps as Ie = Ic + Ib Quote:
No problem... and it give me a chance to play with LTspice which is a bit of a steep learning curve.
------------------------------------------------------- A simulation free zone. Design it, build it, test it. |
#44 |
I always have to think when I see the old Leak troughline... and I just had to Google that and found I'd spelt it wrong because I always think it must be throughline. It's trough as in pig trough though. Quiet and quite is the other one that crops up all the time.
#45 |
So I need to put together an order for parts to build these two circuits. I have the opamp (a 741) and BJT (2n3904/2n3906) but not the emitter follower transistors. I'm looking for suggestions for a few other things to buy that you folks think I might quickly find I want (upgrades) as I'll have to pay shipping and need to get my order up over 10$ anyway. Any tips would be great. I'm thinking:
10 - 2n5401 10 - 2n5550 10 - 10uF caps (ceramic?) 10 - 1000uF caps (ceramic?) I was thinking of getting some of the TIP31 and TIP32C units also as they are used in RJM1's post. I have a few LM741s - is there a "upgraded one" I might want to order also? I also have a large assortment of 5% 1/4 and 1/8 watt resistors. The reason for the capacitors on the order is all of mine are the electrolytic and they are strange values compared to what these circuits are using. Thanks all! |
#46 |
Electrolytic caps in 10, 47, 100 uf are always handy. Depending on what voltages you are working perhaps aim to get 63 volt working. Small film type caps in smaller sizes are useful. Say 0.1uf and 0.22 uf. Anything over these sizes are going to be electroylitic for the circuits you are looking at.
Opamps, it's worth getting a couple of TL071 FET ones. Transistors as you mention plus say BD131 and BD132 and TIP41 and TIP42. These are medium and high power devices... a bit old but easy to work with and easily available. If and when you build a specific design, then that is the time to think of getting specific parts, otherwise common generic parts will allow most circuits to be built and experimented with.
#47 |
Thanks again. My order should arrive today (tomorrow at latest) so I'm excited to build. I was thinking through this in my head today and realized I dont have a volume control.... As I'm testing I may not want this blasting at full volume all the time. Any tips to satisfy this? Or should I control the volume via the input device (ie. blackberry) for now and wait to get into a volume control later?
#48 |
#49 |
You can use the input device for volume control or use fixed resistors at the input to make a divider. There are reasons why a volume control is normally better though. The output of most devices with software controlled output deteriorates at low level while the noise stays the same. So if you amplify that you get a poorer output than setting the device to full output and then attenuating it with volume control which gives no real loss of quality.
#50 |
Molly . Item 31 did you ever get it to sound nice ? I have used it for motor drives . There is a classic design like that which is used to teach current dumping ( Quad 405 ) . Could you simulate it becasue I don't have one using 100 R feed forward resistor ( not 1 K ) and a 3K pull up resistor to - V supply from the op amp output ( pull down if - ? ) . I've got a hunch it will work and it it does I will tell you a story dating back to 1977 . If you have time that is . Looking at 0.01% distrotion I think if it does what I suspect .
| Comments on this basic design | Bootstrapper | Solid State | 70 | 20th December 2010 02:54 PM |
| A basic design description from another site | Consul | Full Range | 16 | 8th April 2007 09:17 PM |
| Tl Basic Design Question. | christophorus | Multi-Way | 37 | 29th November 2004 05:12 PM |
| Basic box design. | MWP | Multi-Way | 2 | 17th November 2003 04:19 PM |
| Basic Q on tube amp design | mrstone | Tubes / Valves | 4 | 20th August 2003 11:22 PM |
