Another Parasound HCA-2200ii owner checking in
Old 24th April 2012, 09:30 PM   #1
johnkramer is offline johnkramer  United States
Default Another Parasound HCA-2200ii owner checking in
Greetings,
So I took the chance on ePray for an HCA-2200ii amp at a great price and I lucked out. It's in great shape even though it wasn't packed well.
Visual inspection doesn't show anything outstanding and it powers up and plays fine.
Two things to note.. It idles warm. The cat loves it. Is this norm? Also, the power up relays are a tad off on power up.. ie. power on, click click. 1 then 2.. about half a second delay. Normal?
It has been fully burned in by me, running constantly for a week with no issues at all. However, due to the age and beasty nature of it, I am thinking of sending it out for a bench check. I'm thinking this is probably a good idea but the purchase was not planned, I simply lucked out on a good deal. Funds could be spent better at the moment but if the powers that be suggest a servicing, off it goes. So what do you all think?
Thanks.
Old 24th April 2012, 09:48 PM   #2
john curl is online now john curl  United States
john curl's Avatar
I would leave it alone, so long as it runs warm.
"Condemnation without Examination is Prejudice"
Old 24th April 2012, 11:49 PM   #3
Thank you sir.
At first I thought the left channel was running warmer than the right until I pulled the top and noticed the rectification on the left heatsink.
Old 7th June 2012, 01:06 AM   #4
Is this considered necroposting?
Anyway. the beast developed a pop in the left channel upon shutdown. As soon as the left relay clicks there is a pop. Any ideas?
Thanks again.
Old 7th June 2012, 01:26 PM   #5
sgrossklass is offline sgrossklass  Germany
Sounds like it's got non-negligible DC offset for some reason, so I'd check that. Why this would be the case, good question. Hard to say without having a schematic at hand.
Old 7th June 2012, 06:25 PM   #6
is there a maintenance manual to be had for this amp?
Old 15th September 2012, 02:26 PM   #7
cgtink is offline cgtink
I had the same problem with the "pop" on shutdown. I contacted Tony at Parasound and he had me take the cover off the amp and tighten the screws on the power supply capacitors. He believed they may have become loose during shipment. It was a simple fix, but it worked.
Another Parasound HCA-2200ii owner checking inHide this!Advertise here!
Holy Capacitor Parasound HCA-2200II Zero Cool Solid State 3 26th March 2017 12:42 PM
parasound HCA-1206 (Tony at Parasound.com) ostie01 Solid State 1 10th July 2012 05:24 AM
parasound hca-1000a infiniti52 Parts 2 11th December 2010 12:21 AM
Parasound HCa 1000a infiniti52 Solid State 10 25th September 2010 12:26 PM
Parasound HCA-2205AT dkahs Solid State 12 19th September 2008 12:36 PM
