diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Solid State (http://www.diyaudio.com/forums/solid-state/)
-   -   57 deg C on a carbon film resistor ? (http://www.diyaudio.com/forums/solid-state/21133-57-deg-carbon-film-resistor.html)
ashok 5th October 2003 11:32 AM
A couple of resistors in one of my circuits are going up to 57 deg C ( constant temp).
They are 2 watt types. Is this an acceptable temperature ? It is about 25 deg C above ambient.
The resistors have a maximum rating of about 150deg C and I wanted to know if anyone knows the long term effects if it is run at 57 dec .
Thanks.
SY 5th October 2003 12:07 PM
Well, the resistance will certainly be different than at room temp. Noise, too. The resistors will survive, but given how cheap they are, I'd make myself happy and put some 4 or 5 watters in that position (doubled-up 2 watters, or 5 watt metal oxide).
ashok 5th October 2003 04:36 PM
Good idea.
Hi Sy,
I was considering that earlier but was not sure if the temperature rise was acceptable. this is just a resistor feeding a zener diode from a 300 volt supply. But I remember having problems ( not my board ) of resistors slowly degrading the pcb at the point of entry of the leads due to high temperatures. I am using glass epoxy boards - still !
yes I think I will use a 5 watter.
Thanks.
Resources saved on this page: MySQL 18.75%
Copyright ©1999-2017 diyAudio
