Suggestions for a very low distortion class A headphone buffer - Page 3 - diyAudio
Old 23rd April 2012, 10:31 PM   #21
ionomolo's Avatar
Send a message via MSN to ionomolo
Originally Posted by bear View Post
You know, the real world implementation of your 0.0001% design is very unlikely to do that right out of the "box" - I suspect that you would have to trim just about everything and match devices to get it there - not to mention the power supply too... I suspect you know that already.
_-_-bear
Agreed, although I'm trying to make a robust design, by using emitter degeneration and lots of negative feedback, so it does not rely (much) on parts. I'm playing with the values and trying to identify which values are the most critical and which ones can take any value within a reasonable range.
Old 23rd April 2012, 10:32 PM   #22
expert in tautology
bear's Avatar
Elvee - that is one heck of a circus you posted! I mean circuit.
Too bad it isn't DC coupled.
I worry about caps in the signal path.
Will have to read that thread again and stare at the schematic until it sinks in. Heh.
_-_-bear
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 24th April 2012, 07:48 AM   #23
Elvee is offline Elvee  Belgium
Elvee's Avatar
_-_-bear
Funny little mind twister, eh?
Agreed on the distortion with discrete devices, you would need to hand-pick them with great care, and couple them thermally, but fortunately there is an alternative, dual monolithic transistors like this one:
http://www.datasheetcatalog.org/data...shay/70758.pdf
This solves all the problems at once.
. .Circlophone your life !!!! . .
♫♪ My little cheap Circlophone© ♫♪
Old 25th April 2012, 02:44 AM   #24
ionomolo's Avatar
I've finally got to my design goal, in spice distortion is 0.00004% with 0.00003% second harmonic and 0.00001% 4rd harmonic at worst case (1V, 20 KHz). At a possible listening level of 0.5V and 2KHz SPICE shows no distortion. Stability seems fine, slew rate is good, and a 5R in series with the supplies doesn't make any difference. I have also played with parts values, and most of them tolerate changes of 50% or more without significant changes in distortion. The symmetric parts seem to tolerate well mismatches of 1%, and I've just bought 0.1% resistors.
Please note that this is a simulation result and I have no idea how the actual circuit will behave. Hopefully I'll be able to post distortion measurements soon .
Please note that I appreciate very much all of the suggestions that people have made, but designing one's own amplifier is a satisfaction I was not going to let go, and I've spent an entire rail of LM4562's building headphone and small loudspeaker amplifiers.
I agree that Elvee's designs are mind-twisting!
Disclaimer: This circuit is the result of a simulation exercise done in good faith and with the intention of building it, however it has not been tested yet and it may behave in unexpected ways. I take no responsibility of anything that happens if you build it, including broken headphones or sources.
Old 1st June 2012, 09:57 AM   #25
Did you build this? I like your idea, and it seems that in has allready been used in a commercial amp
Old 1st June 2012, 10:39 AM   #26
wahab is offline wahab  Algeria
That s a typical so called blameless topology popularized by D. Self
but was in fact used in most 70s opamps , including the 741.
Compensation has seemingly too low cap values , so low that
it s somewhat as much a two pole as a shunt compensation,
the latter being also implemented.
Old 1st June 2012, 11:03 AM   #27
The part I liked was the use of a transformer for voltage gain, I'm not good at reading schematics, so I'm not able to say much about the buffer itself.
Old 1st June 2012, 11:41 AM   #28
The circuit in post 24 doesnt use a transformer at all, except for the supply rails.
Are you really wanting to spend 2000 $ for a heaphone amp only because of its use of a transformer which by the way is technically inferior in all ways I can think of.
You could just spend maybe around 50 euros and get a excellent good sounding headphone amp. I think your wife is going to wring your neck.
Old 1st June 2012, 12:27 PM   #29
As I just noticed I'm no good with schematics, so forgive me if there's any gain in the circuit posted in post #24
But the original idea of ionomolo was to use a transformer for V-gain, so I just took in for granted that he would still do that.
Designing a super low distortion headphone amp. Rainwulf Chip Amps 41 1st April 2011 12:24 AM
Low-distortion Class-A line/headphone buffer linuxguru Analog Line Level 8 13th November 2010 07:00 AM
Low-distortion Super-pair Buffer simulation schematics linuxguru Solid State 29 12th November 2010 09:34 AM
Simple Low Distortion JFET Buffer wrenchone Solid State 21 29th January 2007 08:16 PM
Best low-noise low-distortion buffer? borges Solid State 7 9th December 2003 12:40 PM
Copyright ©1999-2017 diyAudio
