Op-amp tone stack - diyAudio
Old 21st April 2012, 03:25 PM   #1
BRSHiFi is offline BRSHiFi  United States
Previously known as kingden
Default Op-amp tone stack
For a 3 band equalizer tone control circuit, where do you recommend I place the center frequencies for each band? What should I make the bandwidth for each control, aka the frequency range the bass, mid, and high boosts and cuts?
Old 21st April 2012, 04:05 PM   #2
Banned
Just google baxandall tone stack and you should find quite a few verieties of tone stacks.
Old 21st April 2012, 05:29 PM   #3
Most of the baxandall results just show existing circuits. Worst of all they do not give information that answers my question.
http://www.analogzone.com/avt08063.pdf
This pdf is really helpful when it comes to designing narrow-octave equalizers, but I am just looking to do a three band equalizer for now.
For a 3 band equalizer, i simulated a circuit using gyrator band filters that have the following specs:
- Bass: Cutoff frequencies at 10Hz and 400Hz. Center frequency 63hZ.
- Mid: Cutoff frequencies at 400Hz and 5200Hz. Center frequency 1442hZ.
- Treble: Cutoff frequencies at 5200Hz and 30000Hz. Center frequency to be determined.
Do you feel this is a good design, or do you think I should place the center frequencies and cutoffs elsewhere?
Old 21st April 2012, 05:56 PM   #4
Banned
I've never dealt with tone controls.
Old 21st April 2012, 05:58 PM   #5
Frank Berry's Avatar
It's all about your preferences.
Typically, the bass and treble filters are of the 'shelving' variety rather than the bandpass variety.
Let your ears be your guide.
Frank
Old 21st April 2012, 10:36 PM   #6
What is the EQ for?
Take a piece of paper and show us on a graph (frequency vs. gain) what you want. E
Old 22nd April 2012, 01:01 AM   #7
diyAudio Member RIP
Search and you shall find. There is a relatively simple 5 band tone stack
based on the "Cello" recently posted, as well as simpler variants. Its all
been covered before, the ideal tone control is not remotely a new idea.
rgds, sreten.
Old 22nd April 2012, 01:06 AM   #8
Loudthud's Avatar
There is a three band version of the Baxandall you can find on the LF353 data sheet: http://www.ti.com/lit/ds/symlink/lf353-n.pdf
There was an example with equasions in an old National Applications book, but I haven't been able to track that down.
tone stack switchable inductor hewo Instruments and Amps 2 29th March 2011 02:14 PM
Tone Stack Challenge cservonyec Tubes / Valves 13 3rd April 2009 01:51 PM
enough gain for James tone stack PRNDL Instruments and Amps 17 21st December 2007 02:28 PM
Tone Stack Calculator or tsc ??????? prorms Solid State 9 21st December 2006 03:33 PM
Feedback resistor on Baxandall tone stack? porkchop61 Tubes / Valves 3 10th October 2004 02:39 PM
Copyright 1999-2017 diyAudio
