Pre-amplifier grounding compendium?
Old 22nd April 2012, 02:44 AM   #11
Bonsai is offline Bonsai  Europe
That is a very nice article you have written there djoffe. Thanks for sharing your insights.
Old 22nd April 2012, 06:26 AM   #12
Mooly's Avatar
+1
Old 22nd April 2012, 12:03 PM   #13
djoffe is offline djoffe  United States
Gentlemen,
Thanks for the kind words....
Old 25th April 2012, 09:22 AM   #14
gentlevoice is offline gentlevoice  Denmark
+1 from me as well
"... It is always possible to be friendly ..." HH the Dalai Lama.
Old 26th April 2012, 08:15 AM   #15
Hi again,
And thanks once more for sharing your knowledge and insights. I've read up on what you've suggested and have decided on star-grounding in two different places (there are two units) - similar to what is suggested in djoffe's article.
Also, depending on how noisy things become I'll put a copper shield around the interconnect wires and not distance the wires too much from eachother - inspired by the small loop area recommendation in the "HAM" article on RFI shielding.
Also, inspired by one of Bonsai's posts in one of the links you gave, I'll experiment with having the ground and supply wires, e.g. to filter caps lie close to eachother.
I have a question, though: One part of this "preamplifier" really is a microphone with adjacent circuitry, the other part is an A/D converter. All is battery powered, i.e. one battery pack near the microphone(s), another at the A/D converter. If I place a shield around the wires connecting the two parts where would then be the most feasible place to put the connecting point for this shield?
I reckon the shield would pick up high frequency noise e.g. from mobile phones etc., and my own impulse is to connect it directly - through an efficient ferrite bead - to the star ground on the A/D converter's supply and then make sure that this supply is very well filtered high-frequency wise. This already is HF area, and the microphones are very low and volatile signal levels. Does this make sense?
Insights appreciated
Jesper
Pre-amplifier grounding compendium?Hide this!Advertise here!
Grounding in balanced passive pre? Nisbeth Analog Line Level 28 30th March 2012 12:23 AM
Help with Grounding+Layout of Pre+SSamp Combo spice house Solid State 0 19th February 2011 01:16 AM
Supply Topology/Grounding for Pre-amp Bonsai Solid State 20 2nd February 2007 11:04 AM
Pre-pre; phono; pre line ;device discrete (bjt/fet) o op. amplifier GIPIONE Solid State 8 18th December 2005 09:09 PM
pre/amplifier grounding Alkis Tubes / Valves 4 27th February 2005 07:56 PM
