There are 20 Threads with Ampzilla in the title. And another 160 Threads that mention Ampzilla in the content.
Have you looked at any of them?
Have you searched in any of those Threads for Ampzilla111 or III or 3 or ?
Nobody?
I can't believe that!!
Would anybody be willing to scan the article from their Audio amateur and e-mail it to me?
Please help.
Please help.
Is there no one?
Latest info I have is that this amp is tha same as Sumo Andromeda.So maybe someone who has one can help.
Thanks djk
Maybe if I post the schematic good old Alex will design the pcb's 🙂
I need the article so I can make the amplifier.
So did the Sumo.
Substitutes could be chosen, and the compensation changed.
JB say the bias circuit in the Sumo is better, and that a pair of darlington may be substituted for the MPQ6001.
Might be. The bias is supposed to be better compensated for temperature. The frequency compensation is for slower devices and you could probably just drop in current ON Semiconductor devices without too much problem.
A store I worked at sold Sumo, it was OK.
Frankly, the Leach sounded better.
Speedskater,
Can you post those?
djk,
I read somewhere on the net that Leach sounds great in the mid's and highs but has weak bass.Is that true?
Andromeda had some good reviews.
Can you post those?
djk,
"What are those output devices in Andromeda?"
2SC1116A, 2SA747A
"but has weak bass.Is that true?"
No.
If you like warm, muddy bass, just remove the 22µF power supply bypass caps.
"Andromeda had some good reviews. "
Compared to what?
I sold Sumo, Nakmichi, Counterpoint, Adcom, Carver, Yamaha, McIntosh, Harman Kardon Citation, etc, etc.
My Leach sounded quite a bit better.
I had almost everything come through my repair shop: Electrocompaniet, Threshold, Forte, Linn, Mark Levinson, you name it.
The Electrocompaniet and Threshold had promise, the ML sounded much better after some mods.
2SC1116A, 2SA747A
No.
Compared to what?
double barreled
the double barreled i think is much better.. but if you really want the original article of the ampzilla i can send you a pdf copy of it.....just pm me
- Ampzilla III
