Voltage divider? - diyAudio
Old 16th April 2012, 10:11 AM   #1
Default Voltage divider?
Hi Guys,
I want to record the output of my amplifier to show that all amplifiers DON'T sound the same (It's an argument on a another forum).
I have a 60watt per channel Onix OA21 integrated amp. It's modified with some huge polypropylene caps taped to the top of the case (they won't fit in the box). If I change the Ansar polys to Mundorf, I can notice quite a large difference in sound quality and would like to record the difference.
I have a laptop (or PC) with Audacity for recording and an M-audio Mobilepre USB.
Would it be possible to build a voltage divider, so I can take the speaker outputs of my amplifier into my PC or Mobilepre (I asssume it would be better through the mobilepre)?
What do you think Guys?
Old 16th April 2012, 11:52 AM   #2
Try to find the halfler and baxandall amplifier comparison papers.
I think there are many others.
All do a subtraction of some sort to leave the "error" as an output.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 16th April 2012, 12:04 PM   #3
Mooly's Avatar
The amplifiers must be driving the speakers as a load too.
It's an interesting idea. My first thoughts are that you won't see (or be able to record) anything different tbh.
Perhaps prove the recording theory with two totally different amps or using one channel loaded and then unloaded.
Installing and using LTspice IV. From beginner to advanced.
Old 16th April 2012, 12:18 PM   #4
Well, to be exact, they are saying that all low distortion, competently designed amplifiers sound the same. They do exept that SS and valve designs can sound different.
I'd rather prove them wrong with recordings, rather than papers.
Old 16th April 2012, 12:21 PM   #5
If I can hear a difference why wouldn't I be able to record it?
Old 16th April 2012, 12:24 PM   #6
Search out and read the comparison papers.
I think it was Cordell that said something along the lines of
" all amplifiers sound the same when properly designed to pass the signal".
"it's when they are asked to misbehave that they sound different".
When you find his actual quote, I expect it reads a lot different, but I think I have implied a roughly similar message.
regards Andrew T.
Old 16th April 2012, 12:39 PM   #7
How would that help my argument?
Old 16th April 2012, 12:51 PM   #8
diyAudio Member RIP
The answer to your question is yes, you can build a simple voltage divider,
as I assume your amplifier doesn't have floating negative terminals.
1K and ~ 47R would do it, the latter R depending on listening levels.
rgds, sreten.
Old 16th April 2012, 12:52 PM   #9
Didn't think of that. It wouldn't be to difficult to take the signal from the back of the speakers though.
Old 16th April 2012, 12:53 PM   #10
The comparison method and jig enables one to listen to and to measure the "difference".
That is what you are trying to achieve.
You want to show that the amplifiers can sound different.
regards Andrew T.
This novice needs help with Voltage divider jeffreybehr Solid State 11 25th October 2011 10:28 PM
voltage divider in WE91 driver bobluis Tubes / Valves 2 27th August 2010 02:37 AM
Virtual unity gain using voltage divider? Artie Chip Amps 8 17th March 2010 12:20 AM
Precision Voltage Divider - diy redrabbit Equipment & Tools 3 24th July 2008 05:16 PM
voltage divider+Aikido anawat Tubes / Valves 0 17th October 2007 06:19 PM
Copyright 1999-2017 diyAudio
