cyrus 2 amplifier
cyrus 2 amplifier
Old 15th February 2013, 01:40 PM   #81
ftpols is offline ftpols  Japan
ftpols's Avatar
Default cyrus 2 amplifier
Originally Posted by richie00boy View Post
Check what voltage is actually powering the amp. Put black probe on black speaker output socket and red probe on the end of D5 with the white line, note the voltage reading. Now move the red probe to the end of D7 opposite the white line, note the voltage reading.
Hi, Richie.
I followed your advice and read +38.2v at D5 and -19v at D7
Old 16th February 2013, 04:42 PM   #82
richie00boy is offline richie00boy  United Kingdom
Did it Himself
richie00boy's Avatar
cyrus 2 amplifier
38.2 is an expected measurement. It seems that you have something pulling the negative rail voltage down.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 17th February 2013, 12:18 PM   #83
ftpols's Avatar
Hi, Richie.
Thanks for the feedback. I will start testing the circuit after I finish the re-cap, and hope you can help me agin when I get stuck.
Cheers!
Old 1st April 2013, 07:27 AM   #84
ftpols's Avatar
Originally Posted by ftpols View Post
Hi, Richie.
Thanks for the feedback. I will start testing the circuit after I finish the re-cap, and hope you can help me again when I get stuck.
Cheers!
Hi, Ritchie.
After recapping, I still read -19v at D7 and VR1 output reads -37.9VDC instead of -18V. I replaced the VR1 LM337 and recapped C70 (22mf 25V), which was blown. R119 and D12 (resistor) are now running hot.
Can you or any other Cyrus experts kindly direct me to probable source of the problem? Many thanks!
Old 16th October 2015, 08:38 PM   #85
Igor Fritzenstein is offline Igor Fritzenstein  Netherlands
I have the same problem,
i power up the amplifier and the conus form my speaker move up and down.
And i got an buzzing sound like an earthloop since 2 days ago.
Old 13th July 2016, 05:23 AM   #86
naveen francis is offline naveen francis  India
Hello sir,
I m from India, Kindly help me to solve my Cyrus amplifier 2. the issue is while switching off after few seconds some kind of discharging noise through both speakers.if you could give me a hint which section i need to check or which component i need to replace ,,,,,kindly help me .
Old 13th July 2016, 10:04 AM   #87
Mark Whitney is offline Mark Whitney  Netherlands
Mark Whitney's Avatar
Hi Naveen, my Cyrus 2 does the same. It has done this sinds it was new. I don't think that there is anything broken.
Regards Mark.
Old 13th July 2016, 10:40 AM   #88
Hi...Mark
Thank you for your immediate reply to my mail....is there any chance to rectify this issue .i have changed the main capacitors, few 22 mfd 50v, 100 mfd 50v, but this issue is only once we switched off the amplifier after few minutes or few hours. kindly help me mark...also i suspect the 470 mfd 6v bipolar under the ribbon cable but the same is not available here in india.
Old 13th July 2016, 07:18 PM   #89
I know what you mean. I don't think anything is broken as my amp has always done this. You could connect a relay at the outputs of the amp to disconnect the speakers after the amp is switched off. I have never found it a problem.
Regards Mark.
Old 14th July 2016, 05:38 AM   #90
good morning Mark...
When i checked the Dc voltages in both speaker out ...Power on reading 0. and immediate power off reading shows 0.12 and decreasing ...other voltages seems perfect...can you please guide me which is the test point for checking idling current...
cyrus 2 amplifierHide this!Advertise here!
Cyrus One Amplifier - One Channel Silent - What could it be? TylerDurden Solid State 1 15th July 2011 11:25 AM
Cyrus III intergrated amplifier Ashraf Solid State 5 1st December 2009 07:45 PM
Cyrus 3 Amplifier Component Mistakes? hexagonsun Solid State 10 1st December 2009 07:34 PM
WTB Cyrus 1 or Cyrus 2 amplifier monstertrucker Swap Meet 0 20th November 2008 01:04 AM
Cyrus 1 amplifier problem elaar Solid State 2 28th September 2006 10:56 PM
