About my amps mains connections - Page 2 - diyAudio
Old 4th October 2003, 02:29 PM   #11
li_gangyi's Avatar
Cool...I will be waiting for it...
Kids in the back seat cause accidents...Accidents in the back seat cause kids...
Old 4th October 2003, 02:54 PM   #12
sss is offline sss  Israel
sss's Avatar
Send a message via ICQ to sss
Originally posted by li_gangyi
Guess there are no better ways...only a clean relay will do...
well u can use scr's or triacs instead of relays ,its quiet and u dont have to worry how long will they last , but those are far more expensive
Old 4th October 2003, 03:01 PM   #13
li_gangyi's Avatar
SCRs...cool stuff...how many amps will they have to be rated...they aren't really expensive...especially sice you can get some samples from On-semi...but that would mean a power on the gate...meaning it would be close to the full live potential?? or does it just have to be a small signal to switch it on???
Old 4th October 2003, 03:02 PM   #14
HDTVman is offline HDTVman  United States
I'd stick with the relays. SCRs and Triacs tend to make low level hash on the AC line and can be wonderful electrical noise generators.
Later BZ
What ever makes the tunes flow
Old 4th October 2003, 03:14 PM   #15
li_gangyi's Avatar
Hmmm....but still will there be a "super-;ong lasting" relay?? seems they are prone to dying...ahd one crap out in the protection of my amp...took me hours to find it...coz I didn't expect it to fail...replaced the whole channel...just to find that the relay was the culprit...had 2 internal contacts...only 1 was faulty...wonder why...
Old 4th October 2003, 03:23 PM   #16
sss's Avatar
there are scrs available for 1KW of power and higher ,
it works like a switch so the power dissipation is low
noise ? well some amps sensitive to noise , my is not
i'm using voltage regs for input stages
plus most amps that got a current source in the input stage LTP are not sensitive to small noise generated by the power supply
Old 4th October 2003, 03:36 PM   #17
JOE DIRT®'s Avatar
triacs/scr`s are more reliable than relays as I use both in my controls and like any electronic component they have to be treated as such......the on/off cycle life of a triac is far greater than a relay but has to be properly filtered like any electronic component.....it comes down to basic design sense....triacs can become noisy when using them for phasing amplitude but when used as a simple switch they are not any worse than a relay
DIRT®
Old 4th October 2003, 10:20 PM   #18
Rudy is offline Rudy  Belgium
Build this little bugger about a year ago
notes
- relais 1 = mains on
- relais 2 = shorting the currentlimit resistors
- SW1 & D20, i used this one, offcourse the blue one
- R18 is not needed, but it makes the diode to "glow", so you can see if your mains is connected and your 12V supply is on. You need to adjust R17 & R18 if u use a different LED
- You offcourse also need a 12V DC supply
- Dont look at the connections on the TIL111, the pinout is wrong ( not the schematic, just the pins )
- Delay is about 1 sec, adjustabel with R20
For the resistors, don't skip in the budget here, make sure you have about 10Wresistor / 100VA transformer.
Now, the reason why you use this, is already known, you can use a smaller value for the fuse for the main transformer, but try to adjust the resistor ( inrushcurrentresistor ) value to a level that your fuse is smaller then the VA value off the transformer, i use 1.25A for my 300VA transfo, sow if i short my secundairy side, the fuse blows. With the value that is recommended by the manufacturer ( 3A = 700VA ?, the fuse never blows, only the transfo gets hot ) This way your transfo wil never be distroyed.
If you need the rest off the schematic just ask it was to big do to it at once
Greetz Rudy
Old 5th October 2003, 12:58 AM   #19
li_gangyi's Avatar
Is there a simpler way to do it?? Say with a triar (SCR) instead of a relay and because it's an SCR it will be latching...so a 555 timer will do right???
Old 5th October 2003, 02:43 AM   #20
the reason why it is so big is simply the use off a button, not a switch, and the use off the opto and the bridge for that one.
For the SCR's, i just don't like them, i don't put a generator in my amp in combination with an antenna ( transformer ). Relais don't last as lang as the scr, but your telling me you or gonna use your amp for 40years ? I don't think so, and then so what, just replace it after 20 years of so, its max 5buks, sjeez.
And if you are not experienced witch SCR's, meening no RC and proper driving it, hell, it won't last a week. Just a switch and a SCR is a very BAD solution imo. But the same has to be told about the relais, if you use a RC circuit on the relais contacts you won't need to be worried for a few decades.
Greetz Rudy
43% UL connections Hojvaelde Tubes / Valves 18 23rd June 2009 12:00 AM
MAINS... simple, old style amplifier, plugged into mains electrical outlet (110) destroyer X Solid State 2 15th June 2008 02:31 PM
external connections for Chip Amps achristilaw Chip Amps 2 8th February 2005 09:27 AM
Plate amps- high vs low ohm connections? amt Solid State 1 30th January 2004 10:24 PM
Copyright ©1999-2017 diyAudio
