another jung super regulator pcb layout
Old 5th October 2003, 07:28 PM   #21
BrianGT is offline BrianGT  United States
diyAudio Moderator Emeritus
BrianGT's Avatar
Send a message via AIM to BrianGT
Here is the schematic that I drew up for the negative version:
Does this look correct?
Brian
Old 5th October 2003, 07:30 PM   #22
BrianGT's Avatar
Here is a the schematic that I drew up for the positive version:
Note: These are intended for +/- 15v
I posted this for comparison with the negative schematic.
Brian
Old 5th October 2003, 07:40 PM   #23
andy_c is offline andy_c  United States
Banned
Hi Brian,
Looks like pins 4 and 7 of the AD825 need to be swapped on the negative version. So pin 4 should be connected to the negative output of the negative regulator, with pin 7 grounded.
Old 5th October 2003, 07:40 PM   #24
BrianGT's Avatar
Should these two schematics work? They will be about 1" from the actual ICs that they will be regulating, on the same doublesided pcb.
Also, would there be any problems having the +5, +15 and -15 right next to each other? They take up a 3" x 2.1" space for all 3.
Brian
Old 5th October 2003, 07:53 PM   #25
tbla is offline tbla
a 100 nF at the inputpin on the prereg would help......
Old 5th October 2003, 08:02 PM   #26
BrianGT's Avatar
Originally posted by andy_c
Hi Brian,
Thanks, it should be fixed now in the pictures
Anything else?
Brian
Old 5th October 2003, 08:12 PM   #27
Upupa Epops is offline Upupa Epops  Czech Republic
Gentlemen, you are dissecting problem to the " subatomal " plain, and I ask you what is your realy problem ?
Old 5th October 2003, 08:12 PM   #28
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
Brian, check one more time the pre reglator. The regulator should be connected to ground not Vout. The schematics should look EXACTLY the same except for flipped polarities of all parts and pin 7 to gnd and 4 Vout.
/Per-Anders (my first name) or P-A as my friends call me
Group buy: SSR03 Super Regulator Power Supply. Sign up HERE 8 pcb's in interest so far.
Old 5th October 2003, 08:26 PM   #29
peranders's Avatar
Default Re: Re: another jung super regulator pcb layout
Originally posted by BrianGT
I also made the traces a bit fatter (20mils -> 30 mils), and increased the sizes of the pads for the regulator and mosfet, in order to handle heat dissipation better.
I'll guess you regulator won't handle more than 1 A?
For 35 um copper
Signal traces 15 mils at least, 30 mils good
Power traces 40-100 mils or as much as fits.
Maybe the resistor from ADJ to Vout should be a lower value. Datasheets recommend 220 Ohms, 220-330 Ohms is good.
Old 5th October 2003, 09:02 PM   #30
BrianGT's Avatar
Default Re: Re: Re: another jung super regulator pcb layout
For 35 um copper
You are wrong about the regulator connection.
The regulators will be on the pcb with the dac. The 5v one will just be powering the +5 analog side of the dac. The +/- 15v regs will be powering 6 x OPA627BP.
Brian
another jung super regulator pcb layoutHide this!Advertise here!
Jung Super Regulator audionut Solid State 5 7th August 2009 01:07 PM
Jung regulator layout 00940 Solid State 3 27th September 2004 10:59 PM
Copyright ©1999-2017 diyAudio
