Shorted output transistor - diyAudio
Old 10th April 2012, 11:47 PM   #1
Calamaro's Avatar
Default Shorted output transistor
Shorted channel, just changed 2n3055 and mj2955 and driver transistor but now I have 27v dc on speaker terminals...
Old 10th April 2012, 11:56 PM   #2
tvrgeek is offline tvrgeek  United States
Totally out of context, but I would suspect a lot more than the output failed. A schematic or at least what you are working would help.
Old 10th April 2012, 11:57 PM   #3
Banned
The failure may have propagated further back into the frontend circuitry and taken out VAS and possibly burnt some resistors.
Old 11th April 2012, 12:16 AM   #4
Enzo is offline Enzo  United States
One thing to ALWAYS check when transistors burn out is the resistors associated with them. An open resistor can put DC on your output just as surely as a shorted transistor can.
Old 12th April 2012, 06:26 PM   #5
Calamaro's Avatar
Default It still distorts.
Thank you all.
There was another shorted transistor, I've replaced it and now dc offset is ok. But the channel still distorts sounds.
Situation:
found the amp with Q611 burnt and R651 missing (?)
Q613, Q615, Q617 shorted
Q609 seems to be fine
Replaced all shorted transistors, inserted a new 180r resistor (R651).
What else?
Can bias transistor mount on top(body) of output transistor?? Leolabs Solid State 26 28th April 2016 10:34 PM
Pre amp output shorted? SimpleMind Analog Line Level 38 24th March 2012 09:43 PM
If you were to guess what I killed on a F5 when the output shorted? xferboy Pass Labs 11 10th December 2009 12:32 AM
BGW250d shorted output jack...damage? soccerman58 Solid State 4 2nd September 2008 10:19 PM
Designing amp to withstand shorted output mr.duck Solid State 27 27th December 2006 04:02 AM
Copyright 1999-2017 diyAudio
