optimum Vds for 2sk1058 and 2sj162 ?
Old 9th April 2012, 05:02 PM   #1
Bwede67 is offline Bwede67  France
Question optimum Vds for 2sk1058 and 2sj162 ?
Hi everybody,
Somebody could tell me if there is a optimum Vds for 2sk1058 and 2sj162 with
minimum distortion ?
thanks
Christophe
Old 9th April 2012, 06:00 PM   #2
wahab is offline wahab  Algeria
Their Vds is variable depending of the batch , from as low as 0.1 to 0.5V
for 100mA current.
Let s say that there s no advantage in increasing the current over 130/150mA.
Old 9th April 2012, 07:03 PM   #3
fab is offline fab  Canada
fab's Avatar
Are we talking about VDS or VGS here
Old 9th April 2012, 07:58 PM   #4
We talking about Vds because when i look the typical output charactéristics it seems
that the linearity of the 2sk1058 is bad for low Vds.So from what Vds the linearity
become good, and is there a optimum Vds ?
Old 9th April 2012, 11:48 PM   #5
I didnt even notice.....
My answer was for VGS , of course....
Old 10th April 2012, 07:07 AM   #6
Jay is offline Jay  Indonesia
Banned
I don't think that Vds is critical. The Vds imo is about how much power we want to get from the amplifier. But 10V is about the minimum where linearity is guaranteed for normal current/power for amplifiers.
The critical ones are drain current (Id) and Vgs.
We don't want Vgs to be below its threshold, which is batch dependent, but when Vgs is ensured to be able to turn the device on, it seems that higher Vgs is not better soundwise, based on my experiment with Hexfet in Aleph amps. May be because the higher the Vgs, the higher the input capacitance??
Another interesting issue is whether running very high Id (like in Hexfet) is beneficial with Latfets. From my experience I cannot hear improvement with such a high current, but some have noticed that the sound performance is even worse! May be because the switching time (mainly t-on) gets worse when Id gets above 300mA??
I forgot what Hugh (AKSA) had mentioned about this in another thread. I need to copy that.
Old 10th April 2012, 11:16 AM   #7
R.I.P.
The quiescent Vds is set by the PSU voltage.
When the amplifier is passing current to the load the Vds of the output pair is swinging and reaches a limit when Vds = 0 and when Vds= |-V| + |+V|
If the Vds moves towards zero volts then the amplifier begins to distort due to non linearity of the FET's characteristics. The NFB does it's best to attenuate these distortions. But then gives up the unequal battle and we hear clipping and the increase in distortion just before clipping.
If you want to avoid the Vds=0 limiting condition then never drive the output to near clipping. This can be done by giving the output stage higher supply rail voltage than the driver stage. JLH did this with one of his ClassAB FET amps and many thought he got the voltages wrong in the schematic. I think he was simply ensuring best audio quality. That was always what he tried to attain.
regards Andrew T.
Old 10th April 2012, 05:22 PM   #8
Ok, thanks for your reply.
In fact i tried to make a amplifier with only +-21V,but when i watch the typical output characteristics curves(in attachment), i understand why i don't succeed to have a minimum of distortion.
I'll try with higher voltage supply.I'll give a return, by.
Christophe
File Type: jpg typical output characteristic 2sk1058.jpg (67.8 KB, 143 views)
Old 10th April 2012, 06:16 PM   #9
Banned
In fact there is nothing wrong with +-21V. It is just that higher voltage rail makes the design much easier and more flexible. But of course I like very high voltage for class-B mosfet amp.
Old 11th April 2012, 09:12 AM   #10
Christophe
According to this curve a 4V Vgs is enough for the device
to conduct 2.5A at 5V Vds.
This means that an amp with +-21V supply can provide about 16V peak
output level in a 8R load quite easily.
I myself use theses devices , or rather their TO3 siblings 2SK133/2SJ48 ,
in an amp using +-22V supply voltage , although in a triple pair arrangement
that will allow to have lower Vgs for a given output voltage.
optimum Vds for 2sk1058 and 2sj162 ?Hide this!Advertise here!
Anything better than 2sk1058,2sj162 pair? birdyman Solid State 12 11th March 2016 01:48 AM
2SJ162-E and 2SK1058-E 1965GTO Vendor's Bazaar 5 7th August 2012 06:05 PM
LME49811 + 2SK1058/2SJ162 Buslik Solid State 24 15th March 2012 01:45 AM
Anyone know where to get 2SJ162/2SK1058 IN THE US Ivey Parts 8 20th November 2010 12:56 PM
Anyone know where to get 2SJ162/2SK1058 fossil2k Solid State 8 17th March 2008 12:07 PM
