Loudness and power - Page 2 - diyAudio
Old 7th April 2012, 02:43 PM   #11
Banned
Originally Posted by KatieandDad View Post
What is the amp and What are the speakers ?
Audiophiles go a long way to get each right.
Pit a 50W cheap amp against FE a Pass amp and you will hear remarkable differences.
Pit cheap 100W speakers against decent speakers, and with a good amp, you will also hear remarkable differences.
I don't want to criticise your speakers, yet, because we have no idea what they are.
I don't think it's necessary to disclose such private information in order to have a discussion about this topic. I gave you the relevant information about sensitivity, amp rating, room size etc
Old 7th April 2012, 02:44 PM   #12
KatieandDad's Avatar
Originally Posted by wahab View Post
Quite surprising.
I use a 2x16W RMS amp with 90dB or so speakers and it s quite loud
well before full power.
It's been said before - "The BEST amplifier that I ever heard was only 3.5W RMS per channel. It did cost over 3500 though."
Old 7th April 2012, 02:47 PM   #13
Banned
But 3.5 watts isnt enough to go loud with average speakers? I used to have a 15 watt amp and it was easy to get it to distort quickly.
Old 7th April 2012, 03:37 PM   #14
Pano is offline Pano  United States
Pano's Avatar
Then please see rule number two here: diyAudio Rules
Old 7th April 2012, 04:06 PM   #15
A good amp with good speakers will be LOUD at 5W and almost unbearably loud at 50W.
Old 7th April 2012, 04:11 PM   #16
If your 50W amp cannot provide the volume that you require then something is WRONG.
Either the amp is rubbish or the speakers are rubbish.
In a normal listening room 50W is MORE than adequate.
Please refer to ANDREWT post #2
500W will give you double the volume and 5000W double the volume again. This is the nature of human hearing - the logarithmic scale.
Old 7th April 2012, 04:20 PM   #17
At 50W we are talking about the average GOOD home Hi-Fi at FULL-TILT.
The Arcams and the Pass fraternity at maximum power.
Old 7th April 2012, 04:39 PM   #18
I was talking about a World Class Class A Amp.
Please check the spec on the 15W amp, it was probably 15W PMPO which will be well below 15W RMS.
I run my Pass Aleph 4 at High Volume and the TRUE RMS figure is about 6W at GOOD volume. What it does have is ENORMOUS (100W) headroom.
Old 7th April 2012, 05:09 PM   #19
jan.didden's Avatar
If it was linear, we could do basic arithmetic and not have to think as much.
Actually, we CAN do basic arithmetic with dB. 10dB + 20dB = 30dB. Seems simple enough to me
jan
Music is dither to the brain; lets me think below the usual chaos - me
Linear Audio Vol 13 is out! Check out my Autoranger and SilentSwitcher
Old 9th April 2012, 07:15 AM   #20
Measure the voltage at your speaker terminals. With my 90db speakers, I only use about 2 watts when playing at a very loud volume. I doubt that 50 watts is too little for you.
Loudness experiences? Skorpio Solid State 24 27th July 2012 05:58 AM
Loudness Switch thoronx Chip Amps 0 25th February 2008 06:49 AM
The Loudness button 2litre Everything Else 15 25th November 2006 11:04 AM
Power,loudness,sound quality rs1026 Chip Amps 3 29th September 2004 09:45 PM
Copyright 1999-2017 diyAudio
