Enhanched CFP amplifier - diyAudio
Old 5th April 2012, 08:39 AM   #1
Stee is offline Stee  Italy
Stee's Avatar
Default Enhanched CFP amplifier
this idea is NOT tested
please edit your modification
Please download my best audio idea https://www.facebook.com/DiyAudioHiEnd
Old 5th April 2012, 09:10 AM   #2
forr is offline forr  France
forr's Avatar
I suspect it should have better specs than the original, first of all, a better PSRR.
Old 5th April 2012, 10:54 AM   #3
DF96 is offline DF96  England
I can't see any CFPs in that circuit. Have they been 'enhanced' away? I can see an emitter follower, and a complementary feedback triple.
Why don't you tell us about your modifications first?
Old 5th April 2012, 11:12 AM   #4
godfrey is offline godfrey  South Africa
The name's "Hiraga" not "Hiagra".
Indeed, needs work.
Old 5th April 2012, 11:22 AM   #5
Looks like he started with Jean Hiraga's design (below), and broke it.
Old 5th April 2012, 11:31 AM   #6
Stee's Avatar
Indeed, needs work.
please help me
Old 5th April 2012, 02:06 PM   #7
Yes.
please help me
OK. The best help I can give is to suggest you read a good book on electronics (e.g. H&H), then read it again until you understand it.
Old 5th April 2012, 11:03 PM   #8
Stee's Avatar
Default GOOD IDEA
for clipping it's a good solution
reduce bias
about crossover distortion
just reducing gain from 30 to 24
Old 6th April 2012, 01:15 AM   #9
+1 Agreed, unless Stee's contributions are intended as a joke. (Post 8 is ridiculous).
Old 6th April 2012, 09:13 AM   #10
Stee's Avatar
Default A1186 & C.
When you have
(as in this case)
in the power output
collectors in common
need to standardize gain between the two rails
(the output emitter follower has gain equal to one)
for this purpose
advice in the bipolar attached photo
All CFP Non Global Feedback Amplifier Havenwood Solid State 0 7th August 2011 04:17 PM
common source amplifier with CFP output Stee Solid State 2 11th July 2011 03:08 PM
CFP input for JLH amplifier Stee Solid State 1 13th February 2011 01:53 AM
CFP output amplifier - Is it worth the hassle? ash_dac Solid State 1 9th October 2006 01:13 AM
Copyright 1999-2017 diyAudio
