TSSA - The Simplest Symmetrical Amplifier
Old 22nd August 2012, 05:23 AM   #981
Jay is offline Jay  Indonesia
Banned
Originally Posted by jacco vermeulen View Post
Audiolabor Flink (but Class AB, only 4'' high and no heatsinks)
Originally Posted by homemodder View Post
Which model was class A ??
I think all of them are AB, but the older ES model was closer to class-A.
It is strange (and surprising isn't it) how small the heatsink is. According to my calculation the bias is close to 1A. Attached is a picture of the Schnell (2 pairs, not Sankens).
The TSSA doesn't have the nasty clipping.
Old 22nd August 2012, 07:29 AM   #982
Banned
Originally Posted by mikelm View Post
With TSSA the PSRR is not as good as many amps . . . .
I wonder if it would sound better with regulated PSU ?
Any thoughts on that ?
The effect of regulated supply for the front end is very very good. Imo you can avoid the complexity of the front end ccs and cascades and replace them with BJT regulator (2 volts drop in my case). I prefer it that way, without the complex ccs which adds a little (after the regulation) but seems to substract something from the sound. May be different story with different builders and ccts.
Old 22nd August 2012, 08:21 AM   #983
mikelm is offline mikelm  England
Send a message via Yahoo to mikelm
In my fetzilla I use 100R & 4700uF in each rail.
This also works very well also and gives good PSRR - may even be quieter than regulators
At heart I'm a Luddite
Old 22nd August 2012, 08:24 AM   #984
sonnya is offline sonnya  Denmark
sonnya's Avatar
Sorry for being quiet. But i have some PCB to ship today.
Old 22nd August 2012, 08:25 AM   #985
thx for the reminder I have some money to transfer today
Old 22nd August 2012, 09:51 AM   #986
homemodder is offline homemodder  Portugal
What nasty clipping ?? I happen to have repaired a Stark for a friend, it clips perfectly even without the clipping module.
Old 22nd August 2012, 09:56 AM   #987
sonnya's Avatar
Stark "industry" Besides of babes, i think that is fantasy!?????
Old 22nd August 2012, 10:36 AM   #988
I think youre not well informed, does this look like fantasy ???
Old 22nd August 2012, 11:16 AM   #989
Just recieved some interesting info regarding audiolabor, its designer is Christopher Schürmann who is responsible for the design of the Soulution. That explains many things. The Soulution is regarded by many as the best solidstate amps ever made.
Old 22nd August 2012, 11:35 AM   #990
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Back panel of the Schnell is an 8mm aluminum plate, thermally coupled to the solid square bars.
Outer shell is an alloy tubular with 3mm wall thickness, pressed to the framework with bolts (the back panel plus square side bars have threaded holes in the bottom side), >350 square inch total exposed surface.
Fetching half of the MSRP, more than two decades later, likely means they're still much sought after amps.
Tony Stark would have been proud.
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
TSSA - The Simplest Symmetrical AmplifierHide this!Advertise here!
simplest amplifier possible with BJT's? rmgvs Solid State 123 10th July 2008 03:05 AM
Symmetrical Phono Amplifier seroxatmad Solid State 3 6th August 2007 04:00 PM
Simplest class B Amplifier PicancoNet Solid State 42 8th June 2005 02:55 PM
Symmetrical amplifier conundrum Kilentra Solid State 22 31st January 2003 05:06 AM
Symmetrical 400W amplifier Diogo Solid State 30 28th October 2002 11:00 AM
