TSSA - The Simplest Symmetrical Amplifier
Old 13th April 2012, 04:42 PM   #81
Lazy Cat is offline Lazy Cat  Slovenia
Lazy Cat's Avatar
Originally Posted by Idefixes View Post
Hi, LC could adapte the TSSA HP for +/-50Vdc? It would be really nice from you.
For fun il will try the liitle pcb for TSSA TT.
Marc
Originally Posted by Salas View Post
Testing/ironing out TSSA BIGBT, allowing/confirming a range of PSUS 45V-70V and issuing a board would be a happy practical conclusion of the Andrej ideas threads. What is the projected power range for those supply voltages?
TSSA BIGBT HP is high precision CCS driven-defined (1,72 mA source/sink) so all idle conditions depends on this value. Change of the supply potential would be peace of cake stuff, demands only to change the resistance value of the voltage dumping resistors (4 x 56 k, 4 x 22 k). All other parts would stay unchanged if they fulfill minimal potential margins.
So we can produce one amp covering supply DC voltages (rails) from +/- 24-75 V with two pairs of outputs. Power calculations can be done for rehearsal by anyone himself.
P.S. Values of 56 k are wrong, I made calculations with 1,172 mA instead 1,72 in a hurry. So the values will be corrected in a package when we will get few other improvements as well. This version is opened to be polished to high gloss ...
Old 13th April 2012, 04:43 PM   #82
Idefixes is offline Idefixes  France
Idefixes's Avatar
Send a message via ICQ to Idefixes
Thanks for explanation, the question was beacause i have a couple of 2x300va 2x25vac and 22.000/40v caps, so i will probably etch next week the pcb i posted and test with +/-25Vdc rail. I can also swap 3281/1302 TT to 4281/4302 TT to have more marge-in.
Marc
website : http://audiyofield.wifeo.com/index.php
Old 13th April 2012, 04:47 PM   #83
Idefixes's Avatar
So we can produce one amp covering supply DC voltages (rails) from +/- 24-75 V with two pairs of outputs. Power calculations can be done for rehearsal by yourself.
That's a good news, just the LT1034 seems to be a pity to find even no stock on digikey and no to mouser.
Marc
Old 13th April 2012, 04:54 PM   #84
Lazy Cat's Avatar
Marc
TL431 with REF and CATHODE pins connected together would do the job quite the same, only with a little higher noise floor and 50 ppm/C instead 20 ppm/C voltage vs. temperature drift at LT1034.
Old 13th April 2012, 07:02 PM   #85
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Andrej, we don't have expertise about BIGBT or their bias here to calculate on a glance. So, confess it all. 30-150W @ 8 Ohm for that schema?
Old 13th April 2012, 07:53 PM   #86
Idefixes's Avatar
That's a another good news...
A another seems me strange is the IR LED????
Marc
Old 13th April 2012, 07:54 PM   #87
Idefixes's Avatar
When i read that i feel me suddly less alone...
Marc
Old 15th April 2012, 09:45 AM   #88
Idefixes's Avatar
First try for TSSA_BIGBT_HP single layer. 165x135mm. TLP627 is not connected out for moment
Old 15th April 2012, 10:21 AM   #89
Idefixes's Avatar
Just a little precision : BJT Bigbt transistors are mounted under pcb "sandwiched" between pcb and heatsink surface by the screw.
Marc
Old 15th April 2012, 05:32 PM   #90
Idefixes's Avatar
All day was rainy so i continue to play with eagle : consmetics changes and pcb reduction size was on programm
TSSA - The Simplest Symmetrical AmplifierHide this!Advertise here!
simplest amplifier possible with BJT's? rmgvs Solid State 123 10th July 2008 04:05 AM
Symmetrical Phono Amplifier seroxatmad Solid State 3 6th August 2007 05:00 PM
Simplest class B Amplifier PicancoNet Solid State 42 8th June 2005 03:55 PM
Symmetrical amplifier conundrum Kilentra Solid State 22 31st January 2003 06:06 AM
Symmetrical 400W amplifier Diogo Solid State 30 28th October 2002 12:00 PM
