TSSA - The Simplest Symmetrical Amplifier
Old 7th August 2012, 09:40 PM   #881
sonnya is offline sonnya  Denmark
sonnya's Avatar
The schematic is now updated.
The exotic Renesas is gone, so it can be build with standard part except for the Mosfets from exicon or allfet...
I have added comments to the schematic. It is a nobrainer to setup....
There is no thermal runaway. If the mosfets is not mounted correct the current will just adjust down.
The only parts that need to be mounted on the heatsink is the exicon's.....
On turn on they will start with an idle of 750mA and falling to 560 - 600mA within 5 min. And they will stay there.
Add lots of cooling.... at least <0.4K/W.
I have only one comment.... Start building it!! It will reward with an good sound.
If there is any one in denmark that would like to listen to them before building them. They will enter my setup within a week..... Just have to finish the case work.
They will be connected to: MiniPC + itunes + M2tech Young DAC + heimdahl + TSSA V1.6 + Tyr + Raidho C1.1
Old 7th August 2012, 09:58 PM   #882
buzzforb is offline buzzforb  United States
buzzforb's Avatar
Sonnya,
Are you going to do a PCB?
...Shape the sound , Man!
Old 7th August 2012, 10:06 PM   #883
sonnya's Avatar
Originally Posted by buzzforb View Post
Sonnya,
I have done a PCB. There is only very small changes to it. So they will go into the press with 12 hours.
Old 7th August 2012, 10:08 PM   #884
buzzforb's Avatar
Sign me up.
Old 7th August 2012, 10:08 PM   #885
sonnya's Avatar
For how many?
Old 7th August 2012, 10:11 PM   #886
buzzforb's Avatar
2, in case its awesome and brother wants one got the Renasas waiting.
Old 7th August 2012, 10:13 PM   #887
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
So you changed to bipolar drivers. That is interesting because the TO220 laterals are hard to get. I certainly whould like to listen to your amp when i am in Denmark.
Old 8th August 2012, 12:17 AM   #888
grufti is offline grufti  United States
grufti's Avatar
Two for me also. Is that possible?
Old 8th August 2012, 06:04 AM   #889
sonnya's Avatar
It is possible to order as many as needed.
The prices are as following:
Bare PCB - 21/channel
PCB with SMT assembled 39/channel
PCB with all SMT assembled and all parts except heatsink - 102/channel
TSSA module assembled and test on a SK56 150mm heatsink - 253/channel
I would prefer to deliver the modules with all SMT assemblied on the boards. I have tried to sell boards before without SMT assemblied and people did not get them made...
Old 8th August 2012, 06:14 AM   #890
sonnya's Avatar
You are welcome Joachim. Where in germany are you located?
- Sonny
TSSA - The Simplest Symmetrical AmplifierHide this!Advertise here!
simplest amplifier possible with BJT's? rmgvs Solid State 123 10th July 2008 03:05 AM
Symmetrical Phono Amplifier seroxatmad Solid State 3 6th August 2007 04:00 PM
Simplest class B Amplifier PicancoNet Solid State 42 8th June 2005 02:55 PM
Symmetrical amplifier conundrum Kilentra Solid State 22 31st January 2003 05:06 AM
Symmetrical 400W amplifier Diogo Solid State 30 28th October 2002 11:00 AM
