Old 30th May 2012, 12:19 PM   #741
Joachim Gerhard's Avatar
Looks very good Sonnya.
I am also interested if the drivers make any difference.
Old 30th May 2012, 02:19 PM   #742
meanman1964's Avatar
Originally Posted by Idefixes View Post
New tryout on pcb layout, i swap big caps out of board so the pcb mesure 100x56mm
Is this version OK to build?I'm asking cause I've the trannies
Old 30th May 2012, 05:02 PM   #743
Idefixes's Avatar
Send a message via ICQ to Idefixes
No beacause i swap on TSSA BIGBT HP
Marc
website : http://audiyofield.wifeo.com/index.php
Old 31st May 2012, 08:16 AM   #744
Lazy Cat's Avatar
It's OK to build and test, especially in P2P first, to evaluate sound acceptability with your speakers. The mosfet outputs version was checked many times, so you can swap from bipolar to mosfets if the speakers are too low Z - demanding.
Old 31st May 2012, 08:21 AM   #745
Lazy Cat's Avatar
Marc
... something stopped you on the way
Old 31st May 2012, 09:01 AM   #746
Idefixes's Avatar
The sun.....and garden work.... So i need to mesure BC560/550 and KSA/KSC. I want to etch a new pair of board since Irf pinpad are not sufficient nice for me. Eagle introduce larger hole when you switch form screen to printer. So i modify library in consequence. When all that's achieved i need the implementation/test step procedure....
Marc
Old 31st May 2012, 09:08 AM   #747
Lazy Cat's Avatar
Marc
Will do that
Old 1st June 2012, 08:19 AM   #748
Hi Busy Cat
I am a little lost...
please show schem of the the simplest version with mosfets OPT
thank you in advance
regards, Pawel
Old 1st June 2012, 08:39 AM   #749
Lazy Cat's Avatar
Hi padamiecki
The simplest of them all is in post #1.
From there on you can go more complex as much as you like, for example, constant current sources to supply input BJTs emitter current etc.
Regards, Andrej
Old 2nd June 2012, 08:11 PM   #750
Sonnya, you tried to send me a PM but my box was full.
It should work now for a short while.
simplest amplifier possible with BJT's? rmgvs Solid State 123 10th July 2008 03:05 AM
Symmetrical Phono Amplifier seroxatmad Solid State 3 6th August 2007 04:00 PM
Simplest class B Amplifier PicancoNet Solid State 42 8th June 2005 02:55 PM
Symmetrical amplifier conundrum Kilentra Solid State 22 31st January 2003 05:06 AM
Symmetrical 400W amplifier Diogo Solid State 30 28th October 2002 11:00 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
