TSSA - The Simplest Symmetrical Amplifier
Old 25th May 2012, 02:50 PM   #711
sonnya is offline sonnya  Denmark
sonnya's Avatar
Originally Posted by buzzforb View Post
Sonnya,
are you considering selling boards?
Yes i do.
The boards are 75mu copper, and NiAu plated.
The boards without SMT Will cost 21 each.
With SMT They Will cost 39 each.
With All parts They Will cost 103 each and it is without heatsink.
I Can also deliver Them assembled and testet on a heatsink.
This is for the TSSA board only.
The psu board needs to be calculated.
It May Sound expensive but there is No cheap parts in this one. Only good quality parts.
Old 25th May 2012, 04:10 PM   #712
igor0203 is offline igor0203  Slovenia
Sorry if it was asked before...about what power are we talking here about? I mean how many watts does it put out?
Old 25th May 2012, 05:07 PM   #713
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
Sonnya, that looks very good.
Old 26th May 2012, 08:30 AM   #714
Idefixes is offline Idefixes  France
Idefixes's Avatar
Send a message via ICQ to Idefixes
Hi sonny,
KSA/KSC package arrived today. Thanks a lot for all.
Best regards Marc
website : http://audiyofield.wifeo.com/index.php
Old 26th May 2012, 10:16 AM   #715
brianco is offline brianco  Ireland
brianco's Avatar
Location: Scottish Borders - Kelso; on the famous Tweed River!
....and mine also have arrived...Many thanks,
Brian
Old 26th May 2012, 03:45 PM   #716
mikelm is offline mikelm  England
Send a message via Yahoo to mikelm
mine to - thx Sonny
Old 26th May 2012, 03:50 PM   #717
buzzforb is offline buzzforb  United States
buzzforb's Avatar
Sonny. would like to order some PCB's to go with my transistors. Hae o shipped the transistors?
...Shape the sound , Man!
Old 26th May 2012, 04:24 PM   #718
kimon is offline kimon  Greece
Hello Sonny,
how much for two PCBs assembled and tested with heatsinks?
Old 26th May 2012, 07:57 PM   #719
rellum is offline rellum  France
Just found a package in my box. Thanks
Francis
Old 28th May 2012, 10:47 PM   #720
sonnya's Avatar
Ok. I have had the modules running for 12hours each. (please remember that this is without the renesas mosfet)
The do not drift a lot ... Delta 15mV
The idle current is stable. I am running 1.2A.
At +/-25V (18vac) the temp on a sk56 100mm from Fischer is 60 degreess
For +/-32V it is 68 degreess
For +/-36V we are hitting 72.
So the heatsink should be <0.4K/W og 2 heatsinks Per Channel.
In the first test i am a bit surprised as i was expecting tube sound, and this is true for the highs. A bit to soft or to sweet in my opinion... But it is not bad at All!!!
The bass does not suffer under the relatively High output impedance. The bottom and mids is really High class. No softie basguitar and it is easy to distinguese the instruments on Katie Melua - just like heaven.
TSSA - The Simplest Symmetrical AmplifierHide this!Advertise here!
simplest amplifier possible with BJT's? rmgvs Solid State 123 10th July 2008 04:05 AM
Symmetrical Phono Amplifier seroxatmad Solid State 3 6th August 2007 05:00 PM
Simplest class B Amplifier PicancoNet Solid State 42 8th June 2005 03:55 PM
Symmetrical amplifier conundrum Kilentra Solid State 22 31st January 2003 06:06 AM
Symmetrical 400W amplifier Diogo Solid State 30 28th October 2002 12:00 PM
