#61 |
Idefixes, if you have thermal tracks than first make point to point wire nest. Mount TT-s on a heatsink, than step by step add and wire parts, similar like sonnya did. I think it is not very demanding job to do and test, before you go to PCB. You will also check if everything is OK and if the sound is acceptable.
![]() And don't forget to thermally couple input pair.
#62 | |
website : http://audiyofield.wifeo.com/index.php |
#63 |
It is an ideal opportunity to try with P2P, sch is simple, diodes are integrated, so really low parts count. You will also learn how good P2P is, it will hardly be beaten with any PCB.
#64 |
arf no BC560/550 but 2sa970/2sc2240...
#65 |
They are fine, if you can measure hFE, it should be max. let's say 500+
Pinout is different to BC's. It will be very nice to see another wire nest, just go for it and please don't forget to take pics.
#66 |
I not shure to try P2P, bad experience with tube electronics....
A couple of houre with eagle see attachement ... 123x69mm Marc
#67 |
New tryout on pcb layout, i swap big caps out of board so the pcb mesure 100x56mm
#68 |
Hi Idefixes
![]() Very nice little neat PCB. Now you put us all in a expectation ... |
#69 |
Good lord that looks intimidating. It would take me a month just to do the pcb. Might try anyway after the simple tssa.
|F6 Kit/Trasnformer GB Sign up sheet Closed,|Primrose GB Sign Up sheetClick Here ...Shape the sound , Man! |
#70 |
Hi guys
![]() As promised, here's TSSA BIGBT HP. ![]() Credits goes to: Esperado, MiiB, Sonnya, Nico Ras, Salas, Homemodder Andrej
| simplest amplifier possible with BJT's? | rmgvs | Solid State | 123 | 10th July 2008 03:05 AM |
| Symmetrical Phono Amplifier | seroxatmad | Solid State | 3 | 6th August 2007 04:00 PM |
| Simplest class B Amplifier | PicancoNet | Solid State | 42 | 8th June 2005 02:55 PM |
| Symmetrical amplifier conundrum | Kilentra | Solid State | 22 | 31st January 2003 05:06 AM |
| Symmetrical 400W amplifier | Diogo | Solid State | 30 | 28th October 2002 11:00 AM |
