TSSA - The Simplest Symmetrical Amplifier - Page 65 - diyAudio
Old 18th May 2012, 02:05 PM   #641
Joachim Gerhard's Avatar
Correct.
Old 18th May 2012, 02:27 PM   #642
Where does this myth (that ClassA = constant supply current) come from?
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 18th May 2012, 02:39 PM   #643
FdW is offline FdW  Netherlands
FdW's Avatar
I think it was 'Myth Busters', the myth was not 'Busted' True-class-A uses constant current (more or less). Some not-so-true-class-A modes vary the supply current, the judges are still out (if this is class-A or not).
Old 18th May 2012, 03:00 PM   #644
Contant current most of the time.....
Old 18th May 2012, 04:37 PM   #645
ClassA is not constant supply current.
ClassA is a mode of operation that does not invoke crossover distortion.
Constant supply current is a continuous non varying current flowing from PSU to client circuit.
There are some ClassA topologies that draw a virtually constant supply current. These topologies are far outnumbered by the non constant supply current topologies that are available.
Designers and builders very rarely adopt the few constant supply current ClassA topologies.
Far and away the majority of ClassA circuits, irrespective of whether they are Single Ended, or Push Pull, or dual polarity, or single polarity, that we see are not constant supply current.
The most recent posting I am aware of that discussed this non constant supply current was made by me just yesterday. But there are many Threads discussing this myth and and showing the error in the understanding.
My F5T V3 build
regards Andrew T.
Old 18th May 2012, 05:02 PM   #646
mikelm is offline mikelm  England
Send a message via Yahoo to mikelm
From Class A amps with constant current
Old 18th May 2012, 05:03 PM   #647
How many have you seen posted in this Forum?
regards Andrew T.
Old 18th May 2012, 05:27 PM   #648
Ok, before we go deeper i will measure the amp from post 1 ( modified with a CCS ) during music playback ( loud ).
Old 18th May 2012, 05:32 PM   #649
Will you need to add a current measuring sensor into one or other of the supply rails?
0r1 resistor will do the sensor duty.
regards Andrew T.
Old 18th May 2012, 06:04 PM   #650
Nico Ras's Avatar
Andrew's observation is absolutely correct. If the supply current was not modulated obviously there would be no voltage developed across the speaker and of course no sound. Even with SE although the load is a constant current, the supply current is not.
Kindest regards
Nico
simplest amplifier possible with BJT's? rmgvs Solid State 123 10th July 2008 03:05 AM
Symmetrical Phono Amplifier seroxatmad Solid State 3 6th August 2007 04:00 PM
Simplest class B Amplifier PicancoNet Solid State 42 8th June 2005 02:55 PM
Symmetrical amplifier conundrum Kilentra Solid State 22 31st January 2003 05:06 AM
Symmetrical 400W amplifier Diogo Solid State 30 28th October 2002 11:00 AM
Copyright 1999-2017 diyAudio
