#631 |
The monotonic behavior is due to its low OLG. With feedback it is difficult to obtain monotony because of the requirement of the dominant pole. but the lower OLG helps, or should we say masks the performance at lower frequencies.
You could go for a quad pack lateral! ![]() I am waiting on the 2SJ79 and 2SK216. I have a broker that could offer them within 3 days, I need to take more but i will maybe go this path. If i don't get a response. Under all circumstances i know that the parts from the broker is original and checked. Next week i will assemble them for test. (garden needs to be done this weekend) |
#632 |
I am looking forward to your build. It should sound very good as long as you do not push it. On my system with 98dB sensitivity i rarely go over 5 V so in my case it is a very good solution. I think speakers with very low sensitivity is not a good start anyway although there are many out there with huge reputation that are under 84dB but 350kG in weight.
#633 |
Getting some 2SJ79 and 2SK216 is a good investment. I use them in preamps for example.
#634 | |
ha ha ha ha ha.Q3 is down to 2,7Ohm at certain frequencies. I can only agree with you. This one is for effective speakers even horn speakers will benefit from this. Like this: TQWT- But i think Horn speakers are a german landmark.... |
#635 |
My system at the moment is very similar. Waveguide and 20cm bass-midrange but in a dipole with an active m-dipole sub. Yes, horns get more popular here but more in the DIY scene. The so called High End is still the domain of low sensitivity, brute force stiffed, damped and low sensitivity "beauties". This is slowly changing partly because of the grotesque huge power amps that where all the rage 10 years ago. Problem is that many have this amps and they are hard to sell.
#636 | |
![]() Yes I know, but that can also be the reason maybe to visit some other event in near future. Does yours & MiiB's version also consist of two stages only (input-output) or you have some kind of voltage amplifying stage in between? Is it so much different from Sonnya's? ![]() This kind of distortion results are very good considering the input stage has to do everything (differentiating plus amplifying) and for that kind of combination as you already stated, class A would be the best measured-sounding.
#637 | |
Regards, Boyet |
#638 |
Hi Boyet !
Our version is somewhat different from Sonnyas but performance is nearly the same so i recommend you build Sonnyas version. There is a PCB and there is support something that MiiB and I can not supply at the moment because we are very busy in our day job and also have to support the MPP thread. |
#639 |
Here is some information about cap multipliers for class A amplifiers. Capacitance Multiplier Power Supply Filter
For class A they are ideal because there is a constant current draw. For class AB they can be used too but then the output cap that is in this example 1000uF has to be raised to at least 10.000uF. |
#640 |
I do not agree on this one. When you exceed the class A region, the current draw is not constant any longer.
| simplest amplifier possible with BJT's? | rmgvs | Solid State | 123 | 10th July 2008 03:05 AM |
| Symmetrical Phono Amplifier | seroxatmad | Solid State | 3 | 6th August 2007 04:00 PM |
| Simplest class B Amplifier | PicancoNet | Solid State | 42 | 8th June 2005 02:55 PM |
| Symmetrical amplifier conundrum | Kilentra | Solid State | 22 | 31st January 2003 05:06 AM |
| Symmetrical 400W amplifier | Diogo | Solid State | 30 | 28th October 2002 11:00 AM |
