Old 10th April 2012, 09:48 PM   #51
MiiB is offline MiiB  Denmark
nope they are hard to find...sj74 could be an option.. but low idds makes them not so Suitable for CCS.. You need a longer channel higher IDSS part...
a depletion p channel mosfet would be nice.
Old 11th April 2012, 12:43 AM   #52
Bigun is offline Bigun  Canada
Bigun's Avatar
Originally Posted by buzzforb View Post
Who wants to minimize even order distortion Question. If paralleling a resistor with pot, you want the power resistor to be smaller than pot so that it takes the heat, correct
Exactly - the power resistor should be higher in value than what you would calculate for the current you want to achieve, then use a pot that is even higher value so that it draws less current than the power resistor and shunts the power resistor to increase the overall current - adjustably.
If you want to idiot proof it (just in case you're building it for somebody else ) instead of a putting a pot in parallel with the power resistor, put an extra resistor in series with the pot, then put the Pot + series resistor combination in parallel with the power resistor. This extra resistor protects you in the case that the pot is turned down to zero
Originally Posted by Lazy Cat View Post
I could easily do TSSA BIGBT HP since it is much simpler than SSA and potentially even better performer.
yeah ! (I just like the elegance of 'simplest')
hehe almost
Problem is to find and get some good p-jfet, any suggestions
don't do it, CCS's are evil, just say 'no'.... just kidding, although I've never used one (CCS or JFET for that matter)
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 11th April 2012, 07:15 AM   #53
Lazy Cat's Avatar
Hi Bigun
Over the weekend I measured few of them, not for the first time, I did it before also and was never realy satisfied. BJT as cascode in CCS had ten times higher Z100 kHz, noise and much more nonlinear impedance curve over audio band. But the one I posted with jfet cascode impressed me deeply. For rock solid DC current there's precision zener, for perfect AC performance there's jfet.
Jfet itself to form simple CCS is way too much temperature dependent (DC stability is bad) but here in cascode position it feels just perfect, made for this.
Old 11th April 2012, 07:39 AM   #54
I think You saw that Jfet cascode trick in some other thread....
Old 11th April 2012, 07:48 AM   #55
Lazy Cat's Avatar
Yes here. Thank you MiiB
Old 11th April 2012, 05:05 PM   #56
Lazy Cat's Avatar
Hi guys
TSSA all BJT version needs to be thermally compensated, for that reason 1N4148 were replaced by BD139/140 mounted on the heatsink together with outputs, also input BJT pair flats are glued together. In that way amp should be thermally stable even at high output bias current.
Old 11th April 2012, 05:18 PM   #57
Lazy Cat's Avatar
Or even less parts solution with thermal track output transistors, where tracking diodes have double function: bias input pair and compensates thermal drift.
Old 11th April 2012, 05:30 PM   #58
think that it would work better with lateral Fets as they are much easier to drive..
Old 11th April 2012, 05:37 PM   #59
Lazy Cat's Avatar
Agree, for 1 A load current BC's would have to provide extra 10 mA into bases of the outputs. Small power amp only.
Old 11th April 2012, 05:43 PM   #60
Idefixes's Avatar
Send a message via ICQ to Idefixes
LC is it worth to work on a pcb for this, i think i have all parts in stock
Marc
website : http://audiyofield.wifeo.com/index.php
simplest amplifier possible with BJT's? rmgvs Solid State 123 10th July 2008 03:05 AM
Symmetrical Phono Amplifier seroxatmad Solid State 3 6th August 2007 04:00 PM
Simplest class B Amplifier PicancoNet Solid State 42 8th June 2005 02:55 PM
Symmetrical amplifier conundrum Kilentra Solid State 22 31st January 2003 05:06 AM
Symmetrical 400W amplifier Diogo Solid State 30 28th October 2002 11:00 AM
Copyright ©1999-2013 diyAudio
