TSSA - The Simplest Symmetrical Amplifier
Old 14th May 2012, 10:40 AM   #581
sonnya is offline sonnya  Denmark
sonnya's Avatar
The optimum solution would be a chamber with constant temperature and then 1msec. pulses of Ib with Vce drop set to 1 and 5 Volt.
he he he - Next project.
Old 14th May 2012, 02:33 PM   #582
Lazy Cat is online now Lazy Cat  Slovenia
Lazy Cat's Avatar
Originally Posted by AndrewT View Post
The hFE function on most cheap and cheaper DMM is based on a constant Ib. This gives misleading results.
But worse, the Ib is set so low that, the hFE results are for an Ic that is off the left side of most manufacturers' plots of hFE vs Ie.
This combination of design faults makes the added on hFE function a virtual waste of effort and waste of resources.
hFE=Ic/Ib and I put series A-meter with collector and is always 1 mA so Ib is set and measured in a way that Ic=1 mA. I don't see any problem since hFE is symptomatic and consistant as I said recheck always showed the pairs stayed the same by measurement at Ic=100-500 mA.
Old 14th May 2012, 05:17 PM   #583
Idefixes is offline Idefixes  France
Idefixes's Avatar
Send a message via ICQ to Idefixes
Hi LC i just test with DMM KSA/KSC=> sade news as grade are E for KSA and D for KSC, the DMM confirm the fact. I mesure just less 20U eche and the HFE settle between 158 and 165 for KSA and between 85 and 90 for KSC....Justnear double the Hfe from each an other.....
Marc
website : http://audiyofield.wifeo.com/index.php
Old 14th May 2012, 05:38 PM   #584
sonnya's Avatar
I Can supply you with Hfe E group of both types.
Old 14th May 2012, 05:42 PM   #585
Idefixes's Avatar
It would be nice...just need E type from KSC3503 as i have 50x KSA1381 E type but 50x KSC3503 D type....
Marc
Old 14th May 2012, 07:03 PM   #586
Jay is offline Jay  Indonesia
Banned
Default Best Input Transistor
MPSA18 and its family has a maximum of around 1500 hfe (Philips has a maximum around 800). But I cannot even get 700 (with DMM) for my TSSA Still looking and measuring tho...
Accuphase uses discrete input darlington in similar situation. But it is not TSSA anymore...
ADD:
2SC1775A/A872A has hfe around 400-1200
Old 14th May 2012, 07:33 PM   #587
Idefixes's Avatar
LC do you have cross reference for 2SC3503/2SA1381 more easy to purchase? If some one wanted to build tssa HP, this part are and will be more harder to find in the futur...
Tomorrow i hope to acheave mesurement of 50x BC550 and 50x BC560
Old 14th May 2012, 07:41 PM   #588
sonnya's Avatar
I have >5000 each and i would sell 1000 of Them each.
If it reduces your concern
Old 15th May 2012, 05:51 AM   #589
Lazy Cat's Avatar
Hi Sonnya
I would happily buy 100+100
Old 15th May 2012, 08:02 AM   #590
mikelm is offline mikelm  England
Send a message via Yahoo to mikelm
Please put me down for 50 + 50
thx
TSSA - The Simplest Symmetrical AmplifierHide this!Advertise here!
simplest amplifier possible with BJT's? rmgvs Solid State 123 10th July 2008 03:05 AM
Symmetrical Phono Amplifier seroxatmad Solid State 3 6th August 2007 04:00 PM
Simplest class B Amplifier PicancoNet Solid State 42 8th June 2005 02:55 PM
Symmetrical amplifier conundrum Kilentra Solid State 22 31st January 2003 05:06 AM
Symmetrical 400W amplifier Diogo Solid State 30 28th October 2002 11:00 AM
