Old 12th May 2012, 11:20 PM   #571
Lazy Cat's Avatar
Originally Posted by sonnya View Post
Hi all.
The Capbank is finished it fits all CAN style caps with an terminal pitch of 28.5mm
BHC Aerovox
Kemet
RIFA PEH200
A nice suggestion would be:
peh200ko6100mu2
100000uF 40V.
http://sitosite.dk/amps/rifa-capbank.pdf
It uses blade terminals so we can fit AWG12 cables on it.
It uses an external bridge rectifier like GBPC3502 (Place an RC filter across the output of it).
I see very serious approach here 2 x 0,1 F/40 V is expected overkill from you Sonnya.
Old 13th May 2012, 07:37 AM   #572
sonnya is offline sonnya  Denmark
sonnya's Avatar
What i like about them is the low ESR at 10khz of < 15mOhm....
Old 13th May 2012, 05:12 PM   #573
Idefixes's Avatar
Send a message via ICQ to Idefixes
Hi all,
I finally find the time this afternoon to etch TSSA BIGBT HP, need yet to drill
website : http://audiyofield.wifeo.com/index.php
Old 13th May 2012, 09:15 PM   #574
Lazy Cat's Avatar
Originally Posted by Idefixes View Post
Hi all,
Hi Marc
PCB-s are looking great, we're just about to start soldering separate stages and simultaneously testing their functionality. It will be systematic construction process, also very educational one and above all a lot of fun.
Regards Andrej
Old 13th May 2012, 09:48 PM   #575
Idefixes's Avatar
Originally Posted by Lazy Cat View Post
Hi Marc
Regards Andrej
Yes but first have to drill, to mesure BC550/560 and 2SA/2SA (no idee for conditions to achiev mesure for these)....
Marc
Old 14th May 2012, 07:17 AM   #576
Lazy Cat's Avatar
Marc
Regular hFE measurement by multimeter with this function is completely sufficient. Multimeters measure hFE at Ic=1 mA and that is OK for relative matching. Several times I rechecked hFE matching by Ic=100-500 mA by other methods and matched transistors always stayed in the same pairs as defined by multimeter. You are not seeking absolute hFE value of each BJT but using only relative comparison to find best matches.
Old 14th May 2012, 08:09 AM   #577
Idefixes's Avatar
So i must be able to use the schematic below for this use. 0R22 are arrived to...
Marc
Old 14th May 2012, 09:11 AM   #578
Lazy Cat's Avatar
Marc
What's the purpose of this sch? BJT matching I suppose, but why not using hFE function of multimeter? You don't have multimeter with hFE function?
Old 14th May 2012, 09:16 AM   #579
Idefixes's Avatar
Yes BJT matching. My Fluke don't have Hfe fonction. I have another with Hfe function but the DMM is really cheap and basic one. Don't know if i can trust in it. Must check if the Hfe socket is useble for To126 package.
Marc
Old 14th May 2012, 09:53 AM   #580
The hFE function on most cheap and cheaper DMM is based on a constant Ib. This gives misleading results.
But worse, the Ib is set so low that, the hFE results are for an Ic that is off the left side of most manufacturers' plots of hFE vs Ie.
This combination of design faults makes the added on hFE function a virtual waste of effort and waste of resources.
simplest amplifier possible with BJT's? rmgvs Solid State 123 10th July 2008 03:05 AM
Symmetrical Phono Amplifier seroxatmad Solid State 3 6th August 2007 04:00 PM
Simplest class B Amplifier PicancoNet Solid State 42 8th June 2005 02:55 PM
Symmetrical amplifier conundrum Kilentra Solid State 22 31st January 2003 05:06 AM
Symmetrical 400W amplifier Diogo Solid State 30 28th October 2002 11:00 AM
Copyright ©1999-2013 diyAudio
