TSSA - The Simplest Symmetrical Amplifier
Old 8th May 2012, 12:02 PM   #551
Idefixes is offline Idefixes  France
Idefixes's Avatar
Send a message via ICQ to Idefixes
LC i think "Lazy Cat" is absolutly not appropiate, "Crazy Cat" fit you as a surgeon glove on a hand....
Marc
website : http://audiyofield.wifeo.com/index.php
Old 8th May 2012, 12:26 PM   #552
revintage is offline revintage
Did a simple sim of the initial basic schematics and it showed in the ballpark of 2ohm with 1302/0281 and 557/547. But you seem to have a little higher openloop gain now.
So basically this is a transconductance amp that relies on NFB only for lowering Zout?
Old 8th May 2012, 01:39 PM   #553
sonnya is offline sonnya  Denmark
sonnya's Avatar
The front act as an current source in this case and cannot feed enough current to the output BJT's. But add a output driver and the output impedance will Fall.
Old 8th May 2012, 02:19 PM   #554
You are so right, I should maybe have used MOSFET output device when I copied one of the too far simplified schematics.
Old 8th May 2012, 08:01 PM   #555
Idefixes's Avatar
Hi LC, i plane to install a switchable input cap. What will be the best value for?
Marc
Old 8th May 2012, 08:06 PM   #556
sonnya's Avatar
Actually, the bjt set with predriver and 0.1R emitter resistor Will give you lower distortion because of higher transconductance.
Old 8th May 2012, 09:51 PM   #557
Lazy Cat is offline Lazy Cat  Slovenia
Lazy Cat's Avatar
Marc
At 10 kOhm input impedance I suggest to use 22 uF or vice versa 10 uF at 22 kOhm (have to change) input resistor, to get 4,5 Hz/-4dB high pass roll off. Also you need to have input side of the capacitor connected to GND via 1 MOhm resistor to define zero DC potential and to have no clicks by switching AC/DC coupling.
Old 9th May 2012, 08:45 AM   #558
Lazy Cat's Avatar
Originally Posted by Joachim Gerhard View Post
When the transistors are ok the circuit in post 1 works right away.
Hi Gerhard
I own you a great apology not to come to your booth at High End, the reasons are combined (bunch of crazy audiophiles lost orientation sense in a "playground", tight time schedule - one transport ...) and not completely justified I know. Please forgive and hopefully we'll stay cooperative as we were before.
Kind regards Andrej
Old 9th May 2012, 08:48 AM   #559
sonnya's Avatar
Gerhard, what did you display??
Old 9th May 2012, 09:47 AM   #560
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
No problem LC, i was not always at the booth anyway.
I designed a phono amp with tone controls for Fast Audio. The name is Tanzmusik.
TSSA - The Simplest Symmetrical AmplifierHide this!Advertise here!
simplest amplifier possible with BJT's? rmgvs Solid State 123 10th July 2008 03:05 AM
Symmetrical Phono Amplifier seroxatmad Solid State 3 6th August 2007 04:00 PM
Simplest class B Amplifier PicancoNet Solid State 42 8th June 2005 02:55 PM
Symmetrical amplifier conundrum Kilentra Solid State 22 31st January 2003 05:06 AM
Symmetrical 400W amplifier Diogo Solid State 30 28th October 2002 11:00 AM
