#491 |
From today's measurements in my mini lab, and yeah they were extensive, I can tell only this: digital switching amplifiers don't stand a chance against analog amps, especially the ones near future will bring. In the best case scenario, the ratio will be somewhere like photocopy and original relation.
... and Speakers, we have to be thankful them from all our hearts , since this old electro-mechanical technology, still holds the grips, as they only one can transfer music reproduction to our ears and bodies. If that wouldn't be so, not any analog amplifier would be present to this day. Similar happened to analog video equipment and signal long ago, but our ears cannot be fooled as simple as our eyes are, our ears are really special breed, they demand nothing less than pure original or very close presentation only. If you put them just a little extra fake signal to reproduction, our ears-brains organs are not pleased anymore. The only problem I see, likely to happen is, the industry will cancel analog signal from all devices in a reproduction chain. At that point there will be nothing to connect to our inputs ... |
#492 | |
What do you mean you have more modifications? Or it's just handel with installation steps fonction component nature as begining with the lowest parts as diode/resistors and trimmer pre-setting? Marc Nota : i mount Irs 2092 Class D modules. As you stated earlier you don't have to stop your DIY activity. I will not go foward in this way even in Home theater system. My Nmos 200 works a lot better to my mind as the IRS one. More details, more more air, more realistic sound stage. So for Home theater i will go for Nbip quasi version or something other based on AB and BJT OUTPUT (no BIGBT as i haven't more matched since they are reserved for TSSA BIGBT HP) Marc
website : http://audiyofield.wifeo.com/index.php |
#493 | ||
![]() No, no new modifications, everything is as planned. I was just referring that the first build has to be 100% under control, so soldering will be performed step by step according to functional parts of schematic. You'll solder gradually only instructed parts, test functionality of that segmet and than continue to the next step. Don't be affraid, that will be the procedure only for the first two TSSA channels. In this way we'll be sure everything is working properly before connecting precious BIGBT-s. ![]() Quote:
![]() P.S. If you can get your hands on 2SJ79/2SK216 instead IRF-s, do not hesitate even for a second. Regards, Andrej
#494 | ||
On next sunday afternoon i plane to mesure with your process the IRF i have on hand and than order most parts i need to mouser. Marc
#495 |
Hi LC,
Here are some skecth from the TSSA BIGBT HP previsional architecture - front view - internal top view - internal front view - internal rear view Dark grey bloc is the heatsink (265x140x75mm with 11mm base thikness), the one that is on picture attached with the 4x 22.000µf 63V i will use per mono bloc
website : http://audiyofield.wifeo.com/index.php Last edited by Idefixes; 3rd May 2012 at 04:19 PM. |
#496 |
Ok, here it is.
The PDF is interactive, so you can click on the parts. http://sitosite.dk/amps/TSSA-01010512.pdf http://sitosite.dk/amps/TSSA-01010512-pcb.pdf |
#497 | |
#498 |
Send me a board and ill buld it. How about that
. I have started to build one of these several times, just waiting for the dust to settle. Side note; is there such a thing as a small signal lateral. I think they offer a unique sound and want to make sure i am not missing anything. I have about 50 pairs of the Renasas, but noticed others have benn mentioned in this thread.
|F6 Kit/Trasnformer GB Sign up sheet Closed,|Primrose GB Sign Up sheetClick Here ...Shape the sound , Man! |
#499 |
Buzz, focus .... "we " still got work to do ...
#500 |
| simplest amplifier possible with BJT's? | rmgvs | Solid State | 123 | 10th July 2008 03:05 AM |
| Symmetrical Phono Amplifier | seroxatmad | Solid State | 3 | 6th August 2007 04:00 PM |
| Simplest class B Amplifier | PicancoNet | Solid State | 42 | 8th June 2005 02:55 PM |
| Symmetrical amplifier conundrum | Kilentra | Solid State | 22 | 31st January 2003 05:06 AM |
| Symmetrical 400W amplifier | Diogo | Solid State | 30 | 28th October 2002 11:00 AM |
