TSSA - The Simplest Symmetrical Amplifier
Old 1st May 2012, 10:33 AM   #461
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
Good idea.
Old 1st May 2012, 11:14 AM   #462
sonnya is offline sonnya  Denmark
sonnya's Avatar
Last schematic before PCB.
Old 1st May 2012, 11:18 AM   #463
Looks good to me. So you are using 2,2kOhm for R7, R8.
Old 1st May 2012, 11:22 AM   #464
sonnya's Avatar
I will maybe change that but with the predriver there will be an additional vgs drop of 1 - 2V and with the predriver the higher value will not be a problem.
Old 1st May 2012, 01:01 PM   #465
Lazy Cat is offline Lazy Cat  Slovenia
Lazy Cat's Avatar
Hi Sonnya
For the testing purposes schematic is OK, but casoded Sziklai compounds and enhanced rails nested CCS-s were used in the first place to eliminate the need for extra CCS-s, which therefore don't legitimate their presence. Measurements will clearly show if the ratio of benefit vs. unnecessary extra complexity would be justified. In the same manner we can think about using DC servo.
Anyway, I hardly wait to see the PCB layout
Old 1st May 2012, 02:03 PM   #466
sonnya's Avatar
Originally Posted by Lazy Cat View Post
Hi Sonnya
Thats why i have added solderjumps to the ccs bias circuit
Old 1st May 2012, 02:11 PM   #467
Lazy Cat's Avatar
Yes I saw that too.
And there is still possibility no to use Sziklais than these could come handy.
Please say something more about PCB, maybe dimensions, layers, etc. Thanks Sonnya
Old 1st May 2012, 03:36 PM   #468
sonnya's Avatar
Yes I saw that too.
?? Could you explain?
Old 1st May 2012, 10:22 PM   #469
sonnya's Avatar
First layout - placement
Back side of PCB will be mainly GND plane.
Old 1st May 2012, 10:29 PM   #470
As far as i understand Lazy Cat he thinks that your bias arangement is obsolete when we use the Fet Cascoded Sziklay ( FCS ).
TSSA - The Simplest Symmetrical AmplifierHide this!Advertise here!
simplest amplifier possible with BJT's? rmgvs Solid State 123 10th July 2008 03:05 AM
Symmetrical Phono Amplifier seroxatmad Solid State 3 6th August 2007 04:00 PM
Simplest class B Amplifier PicancoNet Solid State 42 8th June 2005 02:55 PM
Symmetrical amplifier conundrum Kilentra Solid State 22 31st January 2003 05:06 AM
Symmetrical 400W amplifier Diogo Solid State 30 28th October 2002 11:00 AM
