Old 30th April 2012, 05:16 PM   #451
Joachim Gerhard's Avatar
We had spring cleaning today and i am building a pair of speakers parallel. i am quite exhausted. I tested the current sources. They work but one channel started to smoke when i cranked the voltage. More testing tomorrow, sorry guys.
Old 30th April 2012, 05:25 PM   #452
MiiB is offline MiiB  Denmark
Don't. stress.....!!!!
Old 30th April 2012, 07:56 PM   #453
What do you think LC ?
I can hand you the modules on the High End and then you can play around with them.
I am simply running out of time.
Old 30th April 2012, 09:02 PM   #454
sonnya is offline sonnya  Denmark
sonnya's Avatar
When you are on the excibition i Will have done the layout.
Old 1st May 2012, 02:23 AM   #455
The vesion with or without the driver or both ?
Old 1st May 2012, 03:09 AM   #456
OK, when i find the time i will make the moduls working. Problem is that i have a lot of guests after the High End so the next two weeks it may be hard to find time for DIY. Anyway, this is exiting.
Old 1st May 2012, 08:39 AM   #457
Lazy Cat's Avatar
Hi guys
A day off from the forum, so where did we stay.
Yes Gerhard, that modules looks great, very compact, just to mine taste hehe
Smoke you said, tiny little black thingy was black before anyway, smoken, no help for him anymore.
So there's obviously some mistake inside that module, plus smoken part to find. We'll use sniffy doggy style to find him, he certainly didn't have a shower in between. That's sorted
Second module stays a side, first one to repair. It's good that it will operate the same with or without outputs. CCS can be isolated and tested separately, for the inputs you have to measure each BJT diodes to check functionality plus correct position in the circuit.
But you already know all that, it's just that your time schedule is too tight to fit in, I know. Well if you don't find a solution before just bring them to High End and we'll discuss from there on.
Old 1st May 2012, 09:04 AM   #458
Lazy Cat's Avatar
Make it small & nasty, little poison.
Old 1st May 2012, 10:01 AM   #459
Today i found a little time so one more round of testing. It must be some really small bug because i am usually good with p-p and perfboard.
Old 1st May 2012, 10:32 AM   #460
sonnya's Avatar
ALF16P16W and ALF16N16W as output with 2SK216 and 2SJ79 as driver.
The ALF has the double gfs than ECX10n20 and ECX10p20 (1.4 - 4S against 0.7 - 2S)
What about a sense resistor in series with the source for setting the idle current. I think of the size of 0.05R!???
simplest amplifier possible with BJT's? rmgvs Solid State 123 10th July 2008 03:05 AM
Symmetrical Phono Amplifier seroxatmad Solid State 3 6th August 2007 04:00 PM
Simplest class B Amplifier PicancoNet Solid State 42 8th June 2005 02:55 PM
Symmetrical amplifier conundrum Kilentra Solid State 22 31st January 2003 05:06 AM
Symmetrical 400W amplifier Diogo Solid State 30 28th October 2002 11:00 AM
Copyright ©1999-2013 diyAudio
