TSSA - The Simplest Symmetrical Amplifier
Old 30th April 2012, 08:56 AM   #441
sonnya is offline sonnya  Denmark
sonnya's Avatar
Originally Posted by Joachim Gerhard View Post
Danke für dass link!
Old 30th April 2012, 09:38 AM   #442
R.I.P.
I have not been spending sufficient time following the details this Thread has exposed recently, so out of ignorance on my part, I ask a question.
Do the use of bc550c/560c as the input pairs raise the likely hood or possibility of stability issues?
Could one of each pair be specified to be lower gain and/or lower fT to help with stability?
regards Andrew T.
Old 30th April 2012, 09:49 AM   #443
Lazy Cat is offline Lazy Cat  Slovenia
Lazy Cat's Avatar
No problem AndrewT
Single transistor pair BC550C/BC560C is rock stable, no instability whatsoever.
Since the wish to improve input pair to have constant power dissipation (cascoded Sziklai) was expressed, it was not tested in practice with TSSA yet. So all useful information of stability and improvement, if any, will be gathered by Gerhard and Sonnya, since they already experienced super simple TSSA from post #1.
Sziklai shouldn't have any instability problems (different with Baxandall) since Vce of input pair have enough headroom to operate in linear conditions, also Ic is almost costant ie. 0,65 mA.
Old 30th April 2012, 10:10 AM   #444
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
I use BC327-40 and BC337-40.
The modules are nearly ready for testing.
I will let them sit for an hour and then double check.
I hope to get the amp working today.
Old 30th April 2012, 10:18 AM   #445
sonnya's Avatar
Replacement for Exicon and Renesas (except 2sk216 and 2sj79)
Magnatec. ALFET Lateral MOSFETs
TT electronics Semelab Limited - Magnatec Datasheets
They are stocked at Farnell.
Old 30th April 2012, 10:30 AM   #446
Semelab also makes the Exicons i think.
Old 30th April 2012, 10:44 AM   #447
R.I.P.
It appears from the various posts around the Forum, that the loss of one factory to a natural event, took down worldwide production of Lateral Power mosFETs.
This may confirm that all current product is based on the same process and the same manufacturer.
Could this be why Laterals are more expensive than Verticals? No competition.
regards Andrew T.
Old 30th April 2012, 10:45 AM   #448
Lazy Cat's Avatar
Very nice looking modules.
Please do not forget to add 2200 uF/10 V elco from latest update.
Old 30th April 2012, 11:47 AM   #449
Elkos added...
Old 30th April 2012, 02:10 PM   #450
modules complete and visually checked
TSSA - The Simplest Symmetrical AmplifierHide this!Advertise here!
simplest amplifier possible with BJT's? rmgvs Solid State 123 10th July 2008 03:05 AM
Symmetrical Phono Amplifier seroxatmad Solid State 3 6th August 2007 04:00 PM
Simplest class B Amplifier PicancoNet Solid State 42 8th June 2005 02:55 PM
Symmetrical amplifier conundrum Kilentra Solid State 22 31st January 2003 05:06 AM
Symmetrical 400W amplifier Diogo Solid State 30 28th October 2002 11:00 AM
