#431 |
#432 |
I design speakers too but that is not a big challange any more after more then 40 years. The only things that are left is radiation pattern and mechanics for me. I do more electronics now.
Yes that latfet drivers are pretty famous for good sound. Anyway, if there is interest i can build a second amp with high current and no drivers. This amp already feels like an old friend to me. I am totally convinced that using the output laterals as current fed back current sources is the way to go. High feedback emitter or source followers have problems to drive a complex load. See the measurements in the new Stereoplay. |
#433 | ||
#434 |
2SJ76 and complementary.
MOQ is 1600pcs each. So there is enough for 800 stereo pairs ![]() Delivery time : 20weeks Price : ~1 - 1.5€/pcs |
#435 |
I use high sensitive speakers at home. One is the Suesskind Sommerwind. It has a 30cm Von Langa fieldcoil in a 140 liter double wall cabinet and a special high sensitivity Mundorf AMT over 1,4 kHz. The other speaker is a G-Pole with 2 Enviee drivers and an active bass. That is an M-frame coupled to the backwall with a granite plate. I recycle the back EMF so that the bass drivers have no excess movement. I am preparing a patent.
You can see some of my setups on my MPL thread. Last edited by Joachim Gerhard; 29th April 2012 at 09:33 PM. |
#436 |
Here you can buy smaller quantities but more expensive.
schulelektronik.de - elektronische Bauelemente - Transistoren - IC´s - STK - Kondensatoren - Widerstände |
#437 |
here is an example.
i also have sources in japan. |
#438 |
Back to back to make up 3400uF NP. We can connect the negatives together (BP) or to connect the positive together (NP) as in Gerhard's and the sound is different. I don't know which one should go into which situation. The last time I tried BP sounded better.
#439 |
No, this is not bipolar but of cause a bipolar can be made that way. I connect minus to minus usually.
Cyryl Bateman found out that this gives less distortion but a "real" bipolar like Nichicon Muse ES has even lover distortion. |
#440 |
Hi guys
![]() Gerhard and Sonnya (and others if any interested) please look at change in schematic. 2200 uF/10 V capacitor added to feedback bridge (from TSSA BIGBT HP and SSA experiences) for extra distortions reduction. This elco decouple middle bridge DC from any AC being present because of unsymmetry, secondly it will cause our amp to raise bias slowly from firing-up, some sort of soft starting. Since this is symmetrical design we don't want anything to spoil our little symmetrical toy. ![]() BTW how's P2P work standing now Gerhard, do I have to wave the finish |
| simplest amplifier possible with BJT's? | rmgvs | Solid State | 123 | 10th July 2008 03:05 AM |
| Symmetrical Phono Amplifier | seroxatmad | Solid State | 3 | 6th August 2007 04:00 PM |
| Simplest class B Amplifier | PicancoNet | Solid State | 42 | 8th June 2005 02:55 PM |
| Symmetrical amplifier conundrum | Kilentra | Solid State | 22 | 31st January 2003 05:06 AM |
| Symmetrical 400W amplifier | Diogo | Solid State | 30 | 28th October 2002 11:00 AM |
