TSSA - The Simplest Symmetrical Amplifier
Old 28th April 2012, 11:55 PM   #401
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
Workarounds are my speciality (:
Old 28th April 2012, 11:57 PM   #402
I will use BF246A to supply the Led.
Old 29th April 2012, 12:09 AM   #403
Lazy Cat is offline Lazy Cat  Slovenia
Lazy Cat's Avatar
OK this one is from 30-80 mA, so may be that 2 k trimmer could not reach enough Ugs to go down to 2 mA. Than add serial resistor to set Id=2 mA
Ideally would be LED current equal Sziklai current, that means both CCS BJTs same current, same Ube characteristic, electricaly plus thermally (coupled together) makes CCS very stable.
P.S. BF246A Uds should be around 10 V for good regulation and AC suppression, if Rgs drops too much to get 2 mA, than lower 12 k to 10 k or less just to maintain Uds=10 Vmin
Old 29th April 2012, 12:11 AM   #404
Lazy Cat's Avatar
Jack of all trades, master ... joke
Yes I see you're very capable and most handy, congratulations
Old 29th April 2012, 12:20 AM   #405
My nickname is Joke by the way. Only my oldest friends know that.
Old 29th April 2012, 12:35 AM   #406
It works without problem. 1,3mA in both channels right away.
Thats it for today.
Was fun, good night.
Old 29th April 2012, 12:35 AM   #407
Lazy Cat's Avatar
Thanks, the name's Lucky
Good night
Old 29th April 2012, 12:39 PM   #408
Most components are on board. Some more wiring has to be done.
Old 29th April 2012, 02:15 PM   #409
Lazy Cat's Avatar
Hi Gerhard
Three amp stages only (input, output, CCS) in TSSA but all black of small signal transistors on your PCBs. 6800 uF feedback elcos
Niceeee
Old 29th April 2012, 02:50 PM   #410
Yes, i had them from another project, does not hurt.
TSSA - The Simplest Symmetrical AmplifierHide this!Advertise here!
simplest amplifier possible with BJT's? rmgvs Solid State 123 10th July 2008 03:05 AM
Symmetrical Phono Amplifier seroxatmad Solid State 3 6th August 2007 04:00 PM
Simplest class B Amplifier PicancoNet Solid State 42 8th June 2005 02:55 PM
Symmetrical amplifier conundrum Kilentra Solid State 22 31st January 2003 05:06 AM
Symmetrical 400W amplifier Diogo Solid State 30 28th October 2002 11:00 AM
