#31 | |
#32 |
Hi buzzforb
![]() TSSA schematic from post #1, built by sonnya, all together four transistors only and as you can see from the pics very promising results.
#33 |
That looks a great deal like one of my amps, although I think his is neater. I have one laterals and BC5XX, sp might as well
|F6 Kit/Trasnformer GB Sign up sheet Closed,|Primrose GB Sign Up sheetClick Here ...Shape the sound , Man! |
#34 |
no additional VAS please - the idea is simplest possible. To heck with THD, if it sounds good it is good
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig. |
#35 |
Just my small contribution...
You prob already have a schematic but I enjoy it and it's late so it may be incorrect !Lazy cat mentioned that cap maybe beneficial so I assumed I could omit it for the neatness of my board please tell me if I'm wrong!
I thought about it once, but then thought again. |
#36 |
I love it, such a simple pcb. Some thoughts...
a) make the pcb longer and cover the power devices, then screw through the pcb, through the power device into the heatsink. You can eliminate the separate pcb mounting holes. b) are you sure you can get 2W rated trimmers of that size ? you may need a power resistor in parallel with a lower wattage trimmer c) leave a little space between the caps d) move the resistors a bit further away from the power device leads which will tend to want a fair bit of solder around them IF I understand correctly, the extra cap helps ensure balance between the two feedback loops, which will minimize even order distortion. I don't think it's a big issue to leave it out.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig. Last edited by Bigun; 9th April 2012 at 12:26 AM. |
#37 | |
Question. If paralleling a resistor with pot, you want the power resistor to be smaller than pot so that it takes the heat, correct
#38 |
#39 | |
![]() ![]() Marc
website : http://audiyofield.wifeo.com/index.php |
#40 |
| simplest amplifier possible with BJT's? | rmgvs | Solid State | 123 | 10th July 2008 03:05 AM |
| Symmetrical Phono Amplifier | seroxatmad | Solid State | 3 | 6th August 2007 04:00 PM |
| Simplest class B Amplifier | PicancoNet | Solid State | 42 | 8th June 2005 02:55 PM |
| Symmetrical amplifier conundrum | Kilentra | Solid State | 22 | 31st January 2003 05:06 AM |
| Symmetrical 400W amplifier | Diogo | Solid State | 30 | 28th October 2002 11:00 AM |
