TSSA - The Simplest Symmetrical Amplifier - Page 33 - diyAudio
Old 27th April 2012, 09:50 AM   #321
sonnya is offline sonnya  Denmark
sonnya's Avatar
I will change the fets to J112 and J175.
They are easier to get and lower nV/SQ(Hz)
Old 27th April 2012, 09:59 AM   #322
Lazy Cat's Avatar
Originally Posted by sonnya View Post
Yesterday evening i made a comparison of mosfet versus NJW1302G/3281G with MJF15030/15031 in darlington configuration with an emitter resistor of 0.22R
idle current is 1.8Amp.
In the simulation the THD for the exicons is 0.014% at 2.8Vp into 8R
for the darlington it is 0.004% at 2.8Vp into 8R
The thing is, they are easier to get, and cost 2/3 of the exicons.
At 1.8A and +/-32VDC we will dissipate 57Watt in each output device.
In comparison the exicons can handle 125Watt and the NJW's 200Watt.
With and heatsink of 0.4W/K the heatsink temperature will rise with 45.6K.
With 57Watt in the exicons it will rise to 102.6K leaving only 47Kelvin to the roomtemperature.
With the NJW you will have 35.625K leaving 68Kelvin to the room temperature.
I do not think it is safe to use the exicons or other devices rated lower than 200W for +/-32VDC supply voltage.
There is a lot talking against mosfets here.
Let me know what you think.
- Sonny
Is it not the same power dissipation at the same bias/rails for both types of devices, resulting in a same temperature increase. Using darlingtons would demand thermal compensation of some sort, laterals can handle without.
Good choice.
Old 27th April 2012, 10:18 AM   #323
sonnya's Avatar
Fine. Then we need to lower the rails.
The layout will not be that different for both types.
So i am going to make two layouts.
TSSA with EXICONS and TSSA with NJW BJT's
Old 27th April 2012, 10:20 AM   #324
Lazy Cat's Avatar
Originally Posted by Joachim Gerhard View Post
The input stage can be improved much, i do not think that it is just the synergy...
Yes, agree about input stage. Synergy, am I missing somehing here hehe
Old 27th April 2012, 10:25 AM   #325
Lazy Cat's Avatar
What if leave +/-32V and lower the bias, it would be fine to have more output swing headroom here. Distortion profile wouldn't change dramatically by lowering bias to let's say 1,5 A?
Old 27th April 2012, 10:28 AM   #326
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
and use BIG heatsinks
Old 27th April 2012, 10:29 AM   #327
sonnya's Avatar
No that is not a problem.
Old 27th April 2012, 10:29 AM   #328
sonnya's Avatar
0.4W/K IS A BIG HEATSINK!
Old 27th April 2012, 10:39 AM   #329
Lazy Cat's Avatar
Than stay on +/-32 V
Old 27th April 2012, 11:19 AM   #330
Lazy Cat's Avatar
This way the current through the input BJT will be the same and symmetrical regardless of bias current and offset adjustment. => Every amp will sound the same way.
What about cascoded inputs? Maybe in this case you wouldn't need extra CCS for bias/offset, as sound would stay pretty much the same regardless input biasing.
simplest amplifier possible with BJT's? rmgvs Solid State 123 10th July 2008 04:05 AM
Symmetrical Phono Amplifier seroxatmad Solid State 3 6th August 2007 05:00 PM
Simplest class B Amplifier PicancoNet Solid State 42 8th June 2005 03:55 PM
Symmetrical amplifier conundrum Kilentra Solid State 22 31st January 2003 06:06 AM
Symmetrical 400W amplifier Diogo Solid State 30 28th October 2002 12:00 PM
Copyright 1999-2017 diyAudio
