TSSA - The Simplest Symmetrical Amplifier
Old 26th April 2012, 01:44 PM   #291
Lazy Cat is offline Lazy Cat  Slovenia
Lazy Cat's Avatar
Originally Posted by sonnya View Post
The OLG will not change much. The open loopgain is more or less set by the RC divided by the feedback resistors which are => 2K2/(36R||1K) => 2K2 / 34 => 65gg
It is multiplied by: (RLOAD/(1/gfs)).
For the exicon (10N20 and 10P20) it is: gfs = 2.5S @ ID=2.5A.
65gg x (8/(1/2.5)) => 1300gg or 62dB.
OLG 62 dB is OK. Distortion spectral profile will be much more clear than before. What do you think, will you test it?
Old 26th April 2012, 02:50 PM   #292
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
I build the circuit from post 1 and also added constant current sources, but floating depletion mosfets. The sound got much better. Less distortion and bigger soundstage.
Old 26th April 2012, 03:49 PM   #293
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Originally Posted by Lazy Cat View Post
I stated output power at -3 dB, so more relaxed, unclipped, not heavily distorted one.
Old 26th April 2012, 04:09 PM   #294
franzm is offline franzm
What type? Siemens/Infineon BSP series?
Old 26th April 2012, 04:11 PM   #295
Supertex, the ones that SY uses in "His Masters Noise".
Old 26th April 2012, 05:27 PM   #296
sonnya is offline sonnya  Denmark
sonnya's Avatar
I am not a fan of pure CLASS A (It is not ECO friendly ) but i will maybe test the attached version.
This way the current through the input BJT will be the same and symmetrical regardless of bias current and offset adjustment. => Every amp will sound the same way.
Old 26th April 2012, 05:36 PM   #297
Tekko is offline Tekko
Banned
I'm saddened to see how ppl nowdays put eco friendlyness before sound quality
Old 26th April 2012, 05:46 PM   #298
sonnya's Avatar
Class AB is fine with me. But Pure class A dissipating +150Watt per channel, i think is a bit over the top when we struggle to keep CO2 emission down.
My own CFP EXICON's runs with 35Watt per channel.
Old 26th April 2012, 06:10 PM   #299
Banned
My current class A amp dissipates around 60-75 watts per channel with a bias of 2.5A, the previous one ran six Amps per channel. My lafet amp(2SK135 and 2SJ50) i have no clue on dissipation as its stone cold despite 150mA bias per channel.
All my other amp project run between 30-70mA bias per channel.
Old 26th April 2012, 06:13 PM   #300
sonnya's Avatar
Sorry i did not want to Pick on you...
TSSA - The Simplest Symmetrical AmplifierHide this!Advertise here!
simplest amplifier possible with BJT's? rmgvs Solid State 123 10th July 2008 03:05 AM
Symmetrical Phono Amplifier seroxatmad Solid State 3 6th August 2007 04:00 PM
Simplest class B Amplifier PicancoNet Solid State 42 8th June 2005 02:55 PM
Symmetrical amplifier conundrum Kilentra Solid State 22 31st January 2003 05:06 AM
Symmetrical 400W amplifier Diogo Solid State 30 28th October 2002 11:00 AM
