Old 24th April 2012, 09:58 PM   #261
Lazy Cat's Avatar
IRF matching, very simple, but it will take you some time hehe
Do not try to find or make a selection of IRF610 and IRF9610 according to Vgs voltage. That is not important. Usually they differentiate for 0,5 V but that is OK as offset setting eliminates this.
Transconductance curves of each type have to be parallel as much as possible. That you will get from three sets of measurements for each type of mosfet. Mark each mosfet with number. Start with 1 by IRF610 and the same with IRF9610.
IRF610 step 1
- take first IRF610 and set potentiometer that you read 100 ohm, read out Vgs and record the value as Vgs-initial-610
- leave potentiometer as it is and measure all other IRF610
- for each numbered IRF610 put a measured resistance value at initial Vgs in a table chart
IRF610 step 2
- take first IRF610 and set potentiometer that you read 50 ohm, read out Vgs and record the value as Vgs-medium-610
- for each numbered IRF610 put a measured resistance value at medium Vgs in a table chart
IRF610 step 3
- take first IRF610 and set potentiometer that you read 10 ohm, read out Vgs and record the value as Vgs-maximum-610
- for each numbered IRF610 put a measured resistance value at maximum Vgs in a table chart
IRF9610 step 1
- take first IRF9610 and set potentiometer that you read 100 ohm, read out Vgs and record the value as Vgs-initial-9610
- leave potentiometer as it is and measure all other IRF6910
- for each numbered IRF9610 put a measured resistance value at initial Vgs in a table chart
IRF9610 step 2 (attention)
- take first IRF9610 and set potentiometer to Vgs-medium-9610= Vgs-initial-9610 + (Vgs-medium-610 - Vgs-initial-610), read out and record resitance value in a table chart
- for each numbered IRF9610 put a measured resistance value at medium Vgs in a table chart
IRF9610 step 3 (attention)
- take first IRF9610 and set potentiometer to Vgs-maximum-9610= Vgs-medium-9610 + (Vgs-maximum-610 - Vgs-medium-610), read out and record resitance value in a table chart
- for each numbered IRF9610 put a measured resistance value at maximum Vgs in a table chart
From IRF610 and IRF9610 table charts you can select the first pair from the ones that have most similar resistance values at all three Vgs voltages. In this way transconductance curves of the first pair are closely parallel-matched. Second pair is the second most matching combination from all three Vgs measurements, etc.
Old 25th April 2012, 01:42 AM   #262
Jay is offline Jay  Indonesia
I lost track as of why IRF matching is discussed in this thread. Anyway, I have been waiting for anyone to mention about TSSA-HEXFET. TSSA-HEXFET is very different with other versions of TSSA/SSA. It is very cooperative (and very useful) and the performance is more like the F5 topology than the other SSA versions.
Old 25th April 2012, 06:11 AM   #263
Lazy Cat's Avatar
I'm just helping to select mosfet driver for BIGBT which is useful for anyone who will try this kind of output.
Hey Jay which specific hexfet are you interested in?
I didn't have time to work more on a TSSA basic, since I was ocupied with SSA upgrade but I promise I will. If you read the thread you can see that Sonnya and Gerhard already made it.
Old 25th April 2012, 06:55 AM   #264
Idefixes's Avatar
Send a message via ICQ to Idefixes
Hi LC new issue : Mouser have different grade for vas : E(hfe 100-200) for KSA and D(hfe 60-120) for KSC....that not top for PNP/NPN matching....
website : http://audiyofield.wifeo.com/index.php
Old 25th April 2012, 07:28 AM   #265
Lazy Cat's Avatar
Yes it is really not the best starting position, but first we have to know few things about (driven) cascodes here. KSA/KSC cascode BJT's hFE in TSSA can hardly influence only to initial DC offset (different voltage drop on R8, R9 as a result of their base current difference), which is in any case calibrated to zero with trimmers.
hFE of KSA/KSC doesn't influence the open loop gain value nor the linearity of TSSA amplifier. Their main job as cascodes is to maintain Vce of VAS gain transistor constant, that results in a reduced power dissipation (stable hFE), constant and smaller Cob (bandwidth extension) of VAS gain BJT. Cascode BJT role is mostly supporting one, main (gain) job here is still on VAS gain transistors (BC550/560C), which have to be matched to be complementary equal.
Old 25th April 2012, 07:37 AM   #266
Lazy Cat's Avatar
Nice supporting circuits you have Idefixes. In a soft-start circuit you could replace R4-R7 with this one.
Old 25th April 2012, 07:47 AM   #267
Idefixes's Avatar
So the main point lay in BC560C/550C matching. We have more room on KSA/KSC as when can calibrate initial DC offset with trimmer, the goal is to not have KSA and KSC at oposite hfe range (60 and 200) but to try to maintain they closed possible to the area 100-120. Have you a cross reference for KSA/KSC maybe 2SC3423/2SA1360 could do the job?
Marc
Old 25th April 2012, 07:51 AM   #268
Idefixes's Avatar
That's a good idee as it save a huge place. This could be used to build the speaker protection in the same board as softstart=> results in wiring simplification.
Marc
Old 25th April 2012, 07:56 AM   #269
Lazy Cat's Avatar
To resume IRF matching described in post #261 in short.
IRF matching is reduced to a form similar like finding the most equal "potentiometers", where mechanical scale is set to a certain position by accu & P, at which Ohm-meter readout is recorded for comparison.
Old 25th April 2012, 08:02 AM   #270
Idefixes's Avatar
Yes LC that was i have understanding from your process description. It's quite clear.
Marc
simplest amplifier possible with BJT's? rmgvs Solid State 123 10th July 2008 03:05 AM
Symmetrical Phono Amplifier seroxatmad Solid State 3 6th August 2007 04:00 PM
Simplest class B Amplifier PicancoNet Solid State 42 8th June 2005 02:55 PM
Symmetrical amplifier conundrum Kilentra Solid State 22 31st January 2003 05:06 AM
Symmetrical 400W amplifier Diogo Solid State 30 28th October 2002 11:00 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
