Old 23rd April 2012, 08:02 PM   #241
Idefixes's Avatar
Send a message via ICQ to Idefixes
Originally Posted by Lazy Cat View Post
Do you plan to use optional +/- 10 V rails for the front-end. It would be a significant improvement for a little cost involved, also the output's stage efficiency would go to maximum.
Perhaps in second time and depend how many space a can dispose in future case. I will see if i can plan it in case conception process. I will need +/-55Vdc to +/-60Vdc more supply. Are this power supply requierement same as SSA? For trafo option are easy. I can find trafo 10Va 2x21V. two of these with secondary in // give me 20Va 2x42Vac so 59Vdc max after rectifying. 2X24Vac ar more easy to find in much wider range of power but that give 2x48Vac with secondary in // so 67Vdc after rectifying.
Marc
website : http://audiyofield.wifeo.com/index.php
Old 23rd April 2012, 08:13 PM   #242
Lazy Cat's Avatar
Let's try with 100 ohm and 47 pF for the input low pass filter
Old 23rd April 2012, 08:17 PM   #243
Idefixes's Avatar
Ok noted in bom list...
Marc
Old 23rd April 2012, 08:20 PM   #244
Lazy Cat's Avatar
Marc
Yes, quite the same, from 5 to 10 V higher rails voltage potential and correct resistors values from the table chart. Serial diode MUR160 plus 22 ohm resistor can stay on PCB without any harm.
Old 23rd April 2012, 08:20 PM   #245
Smiley 09's Avatar
Question SSA or TSSA Front-end for Bal. V12 ?
LC
I'm very impressed with this nice ongoing thread, especially Marc is very intuitive here and I wonder to
congrats both of You for a really very nice and synergistic follow up the simple SSA to become an art.
Andrej I wonder to ask You from Yours enormous experiences which front end would be the best
for the bal. V12 engine to drive: the TSSA or SSA ?
Is the topology for inv. bal pin2 the same as is for the SSA?
After my experience with Nemo I listen music very rarely and wonder to chose the very best front end
for my bal. V12 which is in my slow progress obtaining all semis needed for the proto.
Which Tosh. VAS drivers would You suggest instead the IRF?
I attach the guessed bal. IP for the TSSA. Your sharp eye suggestion & comment would be much appreciated.
Thnx for the answ.
Old 24th April 2012, 04:44 AM   #246
Idefixes's Avatar
Input BC's matching is also very important, as much hFE as possible and the same number for NPN/PNP. VAS KSA/KSC selection is also crucial, etc.
So i grown up my bom list and put in 100x BC550c/560c and 100x KSC3503/KSA1381 => sever amout of work to mesure all in prevision.
Marc
Old 24th April 2012, 07:03 PM   #247
sonnya is offline sonnya  Denmark
sonnya's Avatar
I am sorry, i have off this thread for some time.
I have been working on a softstart unit for remote enable, or IR remote on/off with an idle current of less than 500mW for commercial amp design. It is a requirement from EU and it takes effect 2013. So it is more or less mandatory in new amps.
Marc: it is a nice work you have done (in eagle?) You must have been using a lot of hours on it.
Old 24th April 2012, 07:37 PM   #248
Idefixes's Avatar
Thanks sonnya, yes the work is done on eagle. I play with it since several year so i am relatively aware with this software and creating library in it. Yes it represent a bench of hours. Some people like building puzzle,....and i like spending time on doing layout...The Lazy Cat coaching made it a way more pleasent.
Marc
Old 24th April 2012, 08:14 PM   #249
Lazy Cat's Avatar
Hi guys
Of what I experienced today (SSA), I can guarantee that TSSA will rock hard and will do that in a refined way, just wait and hear, soon. I wish you all a lot of fun building TSSA amplifier, each and every second spent will be fully rewarded.
Regards Andrej
Old 24th April 2012, 08:15 PM   #250
Lazy Cat's Avatar
Will you be present in Munich on High End Show?
simplest amplifier possible with BJT's? rmgvs Solid State 123 10th July 2008 03:05 AM
Symmetrical Phono Amplifier seroxatmad Solid State 3 6th August 2007 04:00 PM
Simplest class B Amplifier PicancoNet Solid State 42 8th June 2005 02:55 PM
Symmetrical amplifier conundrum Kilentra Solid State 22 31st January 2003 05:06 AM
Symmetrical 400W amplifier Diogo Solid State 30 28th October 2002 11:00 AM
Copyright ©1999-2013 diyAudio
