TSSA - The Simplest Symmetrical Amplifier - Page 23 - diyAudio
Old 23rd April 2012, 08:43 AM   #221
Lazy Cat's Avatar
PCB wiring under inspection ... few mistakes revealed.
Old 23rd April 2012, 08:54 AM   #222
Idefixes's Avatar
Send a message via ICQ to Idefixes
......waiting for modification to see if mistake are comimg from schematic or from library (frequently different pin assignation for same part). If schematic and library are right in eagle.....wiring should be right.
Marc
website : http://audiyofield.wifeo.com/index.php
Old 23rd April 2012, 09:02 AM   #223
Lazy Cat's Avatar
Yes, parts pinouts are the reason, nothing dramatical, only few corrections will folow.
I saw very nice equipment in your web page, impressive builts indeed. TSSA should be like one of them, to fit in with quality.
Old 23rd April 2012, 09:09 AM   #224
Idefixes's Avatar
Thanks LC. I am on brainstorming about TSSA casing mix wood/alumium for sure, perhaps glossy lacker as i have painting equipment for (air compressor and car spray-gun)...
Marc
Old 23rd April 2012, 09:17 AM   #225
Idefixes's Avatar
That's a real problem for parts purchasing. With some dealer you are not sure the brand you will have so possible pin layout differences. That's why i like to go to stores as mouser where when order onsemi you have onsemi in packet and for each part type,you can easy have online datasheets.
Marc
Old 23rd April 2012, 11:31 AM   #226
Lazy Cat's Avatar
I am realy curious what listening test will show. Where on your favourite list TSSA will rank. Important and quality selective is also final assembly with wiring especially ground wires and grounding.
Old 23rd April 2012, 12:19 PM   #227
Idefixes's Avatar
That's for sure and can be tricky. The design i have in mind stay on 2 mono blocs. Wiring must be as short as possible. I want to put the distance i can between power wiring and signal wiring. Also main AC wiring must be isolated from the rest as the trafo to. I think to install a steel plate to isolate trafo from rest of amp. For ground wiring i think i will drawn a little schematic a submit it to you.
Marc
Old 23rd April 2012, 12:20 PM   #228
Lazy Cat's Avatar
OK, here's my final check of PCB parts & wiring, also some component's position adjustments to enable wider tracks were done. Hopefully it would be managable, Marc what do you think?
Old 23rd April 2012, 12:38 PM   #229
Idefixes's Avatar
Hi LC i will work on modification this evening. I was sure there was an issue with 2N. It's typicaly the part with pin layout depending manufacturer. The unit i ordered are normaly Fairchild and have different pin layout as onsemi. Is 2N5462 layout OK?
May there is an issue with 0r22 R13 new position see attachement.
Marc
Old 23rd April 2012, 01:02 PM   #230
Lazy Cat's Avatar
Yes, 2N5462 is OK. That in red circle is base track connection, it can be thiner no problem only mA flows. 0,22 ohm were actually moved to sides because of collector connections, tracks flows 10 Ap range current and now can be wider.
What is your favourite amp from your collection, is it Pass Susy?
simplest amplifier possible with BJT's? rmgvs Solid State 123 10th July 2008 03:05 AM
Symmetrical Phono Amplifier seroxatmad Solid State 3 6th August 2007 04:00 PM
Simplest class B Amplifier PicancoNet Solid State 42 8th June 2005 02:55 PM
Symmetrical amplifier conundrum Kilentra Solid State 22 31st January 2003 05:06 AM
Symmetrical 400W amplifier Diogo Solid State 30 28th October 2002 11:00 AM
Copyright 1999-2017 diyAudio
