TSSA - The Simplest Symmetrical Amplifier
Old 22nd April 2012, 03:35 PM   #211
Idefixes is offline Idefixes  France
Idefixes's Avatar
Send a message via ICQ to Idefixes
Originally Posted by Lazy Cat View Post
Good, good Marc, I like it a lot
Last corrections from me and than I rest my case, PCB can be final:
- C17 100 pF, put three pads/holes as with C8, C9 (5 mm, 7,5 mm)
- move input connector J10 to the middle (symmetry line) and resistor R3 near R36, in that way both connectors J3 and J10 will be aligned
- move two NTC pads closer to R24, and make a screw access hole larger
- J9, J8 are not the same distance away from J5, please correct it
- if possible leave the body of IRFs on the same spot, only align their pads with MJLs, if parts library allows that modification. It would be nice to have pins aligned, also pin leads of IRFs would be shoter (this is the main reason), but please do not move the cases of IRFs
- C12, C15, C41, C42, C43, C45, C46, C47 1 uF film capacitors should have third pad for 5 mm pin distance case, which are quite common on the market
Regards Andrej
P.S. Other answers will follow at the evening
Here for update
Marc
website : http://audiyofield.wifeo.com/index.php
Old 22nd April 2012, 04:00 PM   #212
Lazy Cat is offline Lazy Cat  Slovenia
Lazy Cat's Avatar
Mark awesome
Only one little beauty remark hehe, look C8 and C15, what is the difference? Something about silk screen layer and this artefact should be corrected all over the PCB.
Old 22nd April 2012, 05:06 PM   #213
Idefixes's Avatar
Mark awesome
For you Sir...
Old 22nd April 2012, 05:42 PM   #214
Lazy Cat's Avatar
Hehe you corrected C15 but at the same time something happened with C8. At other places too.
Old 22nd April 2012, 05:49 PM   #215
Lazy Cat's Avatar
C17, C8, C9, C44, C47, C56 capacitor symbol over the pad
Old 22nd April 2012, 05:51 PM   #216
Idefixes's Avatar
this time i don't see, all symetrical above from down to top????
marc
Old 22nd April 2012, 06:32 PM   #217
Idefixes's Avatar
Okayyyyyyy....
Marc
Old 22nd April 2012, 06:53 PM   #218
Idefixes's Avatar
Here....One thing is clear, TTSA layout was really rewarding for me. Thanks for all.
Old 22nd April 2012, 07:40 PM   #219
Lazy Cat's Avatar
I believe that Marc.
C17
Old 22nd April 2012, 07:44 PM   #220
Idefixes's Avatar
C17
Sheeeeet.
TSSA - The Simplest Symmetrical AmplifierHide this!Advertise here!
simplest amplifier possible with BJT's? rmgvs Solid State 123 10th July 2008 03:05 AM
Symmetrical Phono Amplifier seroxatmad Solid State 3 6th August 2007 04:00 PM
Simplest class B Amplifier PicancoNet Solid State 42 8th June 2005 02:55 PM
Symmetrical amplifier conundrum Kilentra Solid State 22 31st January 2003 05:06 AM
Symmetrical 400W amplifier Diogo Solid State 30 28th October 2002 11:00 AM
