TSSA - The Simplest Symmetrical Amplifier
Old 22nd April 2012, 12:21 PM   #201
Idefixes is offline Idefixes  France
Idefixes's Avatar
Send a message via ICQ to Idefixes
Originally Posted by Lazy Cat View Post
Will you use 88.000 uF for one channel?
I have allready 4u 22.000uf 63V U32D chemicon nipon (diam 35mm L=115mm) and wanted to had a another set. The goal is to be abble if it's possible to drive for domestical use some 3ohms speaker (2.5way speakers for exemple or 2 way speakers with two woffer in parallel)
EPCOS - B57703M103G40 - NTC Thermistor
The last one puts everything in a new perspective regarding NTC PCB installation, it can be mounted and soldered the same way as IRFs, no need for two extra pins.
That's the way to go.
Past few day i ask you a little question about BIGBT BJT selection
Originally Posted by Idefixes View Post
I take a look at NJW3281G/1302G datatsheet. They seems to good candidat for job as NPN/PNP gain matching is giving in 10%, that let good matching previsions between NPN and PNP after HFE/Vbe mesuring session.
For layout I need to rework to see if i can gain space et reducing traks length, but i am in single layer....that not easy. Pearhaps i can do something with TSSA core to bring it back, more closely to BIGBT module.
Marc
The next things is to fix the IRF610/9610 driver selection.....think diy-beginner will ask question.......not only me.....
Marc
website : http://audiyofield.wifeo.com/index.php
Old 22nd April 2012, 12:30 PM   #202
Idefixes's Avatar
Originally Posted by AndrewT View Post
Do R3 & R36 need to be so low?
What deteriorates if 100k and 1k are adopted?
What values are C1 & C2?
2.2mF or 22mF.
I can't make out a decimal point. I prefer 2m2F instead of 2.2mF. It is unambiguous and generally recognised worldwide.
Reported to component voltage value and size this are 2m2uf or 2200uF if you prefer. Same 1mf = 1000uF
Marc
Old 22nd April 2012, 12:39 PM   #203
I know and you know that m is short for milli and that m is generally accepted to be the multiplier, 10^-3
But that is not what I am asking.
It's the near invisibility of a decimal point that is causing the ambiguity.
Use 2m2F to avoid 2.2mF being mistaken for 22mF.
Now back to the question: what are the values for C1 & C2? 2m2uF, what the **** is that?
regards Andrew T.
Old 22nd April 2012, 12:44 PM   #204
..........The next things is to fix the IRF610/9610 driver selection.....think diy-beginner will ask question.......
I think the question is whether or not to avoid irf9xxx due to the way IRF make their P channel mosFETs.
What about Fairchild, or any of many others, who/that seem to have avoided this manufacturing characteristic (or is it a defect that is tolerable in switching applications).
regards Andrew T.
Old 22nd April 2012, 12:49 PM   #205
Idefixes's Avatar
I understand andrew and apply what you suggest(see under). For your value proposal let LC answer...
Marc
Old 22nd April 2012, 12:55 PM   #206
f=femto
F=Farad
correct that mistake.
the multiplier is used instead of the decimal point.
2m2F is different from 2mf2 and is different from 2mF2
I see 0R22 elsewhere. Good, no confusion.
regards Andrew T.
Old 22nd April 2012, 01:07 PM   #207
Idefixes's Avatar
f=femto
F=Farad
So no confusion possible, no?
Old 22nd April 2012, 02:07 PM   #208
Lazy Cat is offline Lazy Cat  Slovenia
Lazy Cat's Avatar
Hi AndrewT
Look here's the original schematic, where you can clearly see 2,2 mF. This sort of value marking occupies less space on a schematic than 2.200 μF
Old 22nd April 2012, 02:27 PM   #209
Lazy Cat's Avatar
Here we go, R1/C1 value are these from SSA schematic form moment until value is fixed. The add of latest component don't let keep the nice input area symetry we had in previous version.
Marc
Good, good Marc, I like it a lot
Last corrections from me and than I rest my case, PCB can be final:
- C17 100 pF, put three pads/holes as with C8, C9 (5 mm, 7,5 mm)
- move input connector J10 to the middle (symmetry line) and resistor R3 near R36, in that way both connectors J3 and J10 will be aligned
- move two NTC pads closer to R24, and make a screw access hole larger
- J9, J8 are not the same distance away from J5, please correct it
- if possible leave the body of IRFs on the same spot, only align their pads with MJLs, if parts library allows that modification. It would be nice to have pins aligned, also pin leads of IRFs would be shoter (this is the main reason), but please do not move the cases of IRFs
- C12, C15, C41, C42, C43, C45, C46, C47 1 uF film capacitors should have third pad for 5 mm pin distance case, which are quite common on the market
Regards Andrej
P.S. Other answers will follow at the evening
Old 22nd April 2012, 03:08 PM   #210
less than 2m2F? and less ambiguously when the decimal point cannot be seen?
I cannot understand why anyone would want to write 1000uF instead of 1mF, nor 100000uF instead of 100mF, nor 0.0000027uF instead of 2p7F, even 0.0027nF would be a nonsense.
Farad is the basic unit, all others are Farads and a multiplier. Choose the multiplier that best suits the value being displayed, but overall, make it unambiguous.
BTW,
2.200 μF
means 2u2F to me and others who understand the decimal point usage.
regards Andrew T.
TSSA - The Simplest Symmetrical AmplifierHide this!Advertise here!
simplest amplifier possible with BJT's? rmgvs Solid State 123 10th July 2008 04:05 AM
Symmetrical Phono Amplifier seroxatmad Solid State 3 6th August 2007 05:00 PM
Simplest class B Amplifier PicancoNet Solid State 42 8th June 2005 03:55 PM
Symmetrical amplifier conundrum Kilentra Solid State 22 31st January 2003 06:06 AM
Symmetrical 400W amplifier Diogo Solid State 30 28th October 2002 12:00 PM
Copyright ©1999-2017 diyAudio
