#11 |
I Will build it tomorrow and run it on an analyzer
#12 |
Sonnya you're the Man!
#13 |
I thought Sonnya is/was female.
#14 |
I entertained that idea and I liked it, but I did it in a different manner...
![]() Off course, using Laterals exclude the need for thermal compensation. 1. Basic idea (post #8231): F5 power amplifier 2. Working amp (post #6): Radjanje F5 clone - diyaudio.rs |
#15 |
Male - i cannot multitaske
#16 |
For some reason, the last time we cleaned out in the old component stock we have thrown out all TO-92 bjt!!!!
![]() So i am building it today with KSC3503 and KSA1381. I think the would be a good substitute besides from the gain. But driven from a Low z source it should not be an issue |
#17 |
#18 |
#19 |
1K trimmer is replaced by a 2k2 fixed and in the negative part 1k + 2k trimmer.
RC top and bottom is set to 2.2k=> more OLG. BC550 and 560 is replaced by KSC3503 and KSA1381. at 24V it will settle to about 1.2 - 1.4 amp. for an equal current in the mosfet an vgs difference on the 10n20 and 10p20 from exicon of about ~1V. This will lead to and offset. Maybe a diode in series with one of the collector resistors will help a lot!?. I have attached the measurements. |
#20 |
The amp.
| simplest amplifier possible with BJT's? | rmgvs | Solid State | 123 | 10th July 2008 03:05 AM |
| Symmetrical Phono Amplifier | seroxatmad | Solid State | 3 | 6th August 2007 04:00 PM |
| Simplest class B Amplifier | PicancoNet | Solid State | 42 | 8th June 2005 02:55 PM |
| Symmetrical amplifier conundrum | Kilentra | Solid State | 22 | 31st January 2003 05:06 AM |
| Symmetrical 400W amplifier | Diogo | Solid State | 30 | 28th October 2002 11:00 AM |
