TSSA - The Simplest Symmetrical Amplifier - Page 19 - diyAudio
Old 21st April 2012, 01:52 PM   #181
Telstar is offline Telstar  Italy
Will take awhile, I dont have a stabilized psu yet. I want to make one adjustable (9-12-15-18 at least) to try various designs in most comparable conditions.
"The total harmonic distortion is not a measure of the degree of distastefulness to the listener and it is recommended that its use should be discontinued." D. Masa, 1938
Old 21st April 2012, 05:20 PM   #182
Idefixes's Avatar
Send a message via ICQ to Idefixes
Hi LC here latest version, i had to move a litlle some parts to let space for traces.
website : http://audiyofield.wifeo.com/index.php
Old 21st April 2012, 08:55 PM   #183
Lazy Cat's Avatar
Let me think, mhmm I see that you're shy a little, don't be affraid to do things more in a radical way ... so:
- R33, R34 are half way there as in post #175. You have to move them as in pic, away from the heatsink, now they are just too close, 3 mm would be just fine to avoid short connections, etc.
- C13, C16 polarity-pins should be oriented as C40, C44, I measured the distance from inner pad to close by track and it fits to place perfectly. So put them as in pic #175. Look, if someone is beginner and tries to make an amp as fast as possible, than there are lot of chances to misalign the polarity, cause there is 90° rotation, plus upper and lower elco not having the same orientation. In such cases we always try to make things typically to reduce possibilities of errors.
- C5, C6 are probably silver mica caps, 7,5 mm pins distance. OK, someone would like to use 5 mm pin distance ceramic caps, so please put one extra pad to each cap, that both sizes could fit
- R16, R28, R32, R40 move all four 22 ohm resistors 2 mm in a direction to the center of PCB. Reason? R40, R28 are to close to the fuse metal holder, preventing the shorts at misalignment
- ZD7-ZD10 should have pad distance of 7,5 mm. Middle two pins of serial zeners holds the current position, outer pins goes closer. Why? You will gain a space to flip R23, R24 horizontally
- R23, R24 should change positions (fliped horizontally). Why? NTC will in that way go closer to the outputs and also will be easily soldered/desoldered when/if PCB is serviced. NTC is glued into the heatsink's hole just bellow its pads. NTC is fixed inside the heatsink and there is better place away from the trimmer for soldering/desoldering
On a first look these are all insignificant changes but certainly makes difference, as assembly is easier and more safe, especially for beginner DIY-ers.
Regards, Andrej
Old 21st April 2012, 09:14 PM   #184
palmito is offline palmito  United States
palmito's Avatar
Thank you for remembering us...
Old 21st April 2012, 09:19 PM   #185
Lazy Cat's Avatar
Palmito you're welcome, I mean, to make one of these
Old 21st April 2012, 09:43 PM   #186
palmito's Avatar
I will if the pcbs become available, don't trust my p2p abilities yet... Thanks again.
Old 21st April 2012, 10:02 PM   #187
Idefixes's Avatar
Regards, Andrej
Andrey don't you think there is a contradiction in what you wrote : Diy-Beginner and
My self, i don't be diy-beginner in soldering and case construction but here i can easily imagine the mounting phase but one time the NTC glued in heathing with previous soldering on pcb....i can't imagine how to desolder this NTC from PCB since it lay in middle of the pcb and here solder pad are quite unreacheable with solder iron?????? Marc who's driving nuts on this spécific point. So for the rest of request i try something....see under.
For ZD 7-10 i try something without modifying the zener part library or create new one....
Old 21st April 2012, 10:07 PM   #188
Lazy Cat's Avatar
Yesss I forgot that there's no pads on top layer I always have double layer PCB-s, so now we have a problem. NTC would be the best to put in heatsink hole and glue it but how to connect it without using wires mhmmm
Old 21st April 2012, 10:20 PM   #189
Idefixes's Avatar
What we can built pseudo tracks that bridged bottom and top layer. This can be done by cuted pin from resistors. When this bridge are in place NTC can be soldered in P2P mode. I don't know if my description is clear....
Marc
Old 21st April 2012, 10:24 PM   #190
Lazy Cat's Avatar
NTC on the top of PCB can be connected by help of two extra pins located nearby. Through holes for NTC serves to giude pin-wires to extra pins and solder the damn thing on the top.
Four holes for C8, C9 is way to much, look to the pic of what I meant.
simplest amplifier possible with BJT's? rmgvs Solid State 123 10th July 2008 03:05 AM
Symmetrical Phono Amplifier seroxatmad Solid State 3 6th August 2007 04:00 PM
Simplest class B Amplifier PicancoNet Solid State 42 8th June 2005 02:55 PM
Symmetrical amplifier conundrum Kilentra Solid State 22 31st January 2003 05:06 AM
Symmetrical 400W amplifier Diogo Solid State 30 28th October 2002 11:00 AM
Copyright ©1999-2017 diyAudio
